April 13, 2018, 14:58 |
0/T file magically changes
Robbe
Rep Power: 8 |
Hi fellow foamers
First of all, I am still new to OpenFOAM, so hopefully I am not making an obvious mistake here... Any suggestions are much appreciated I am using reactingFoam (OF v5) to simulate fuel injection in a constant volume chamber filled with air, starting from the DLR_A_LTS tutorial. I set up the boundary conditions similarly to the article of Som (2012), resulting in an initial chamber temperature of 1000 K. As boundary conditions, I used an injection temperature of 373 K at the injector orifice, and a zeroGradient at the walls of the domain. Currently I have no outlet, as I would like to study the interaction of the fuel with the walls. I specified all values in the T file and copied it to T.orig such that both are exactly the same. Then, when I try to run the simulation, I see that (out of nowhere) the T file is replaced and the value for the initial conditions are replaced with the fuel temperature (so from 1000 K to 373 K)! As a consequence, my entire temperature field in paraview is not what it should be... The weird thing is that the T.orig file is still the same. I checked the Allrun file and took out the line that copies T.orig, but it did not change anything. Does someone have an idea of what's happening here? Also, could someone point out why exactly there exists an .orig file for temperature, but not for p and U for example. Thanks in advance, and have a nice weekend! Robbe P.S.: For clarification, I included both the T files. The first one I made, the second one appeared after the simulation. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 1000; boundaryField { injector { type fixedValue; value uniform 373; } walls { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class volScalarField; location "0"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 373; boundaryField { walls { type zeroGradient; } } // ************************************************************************* // |
April 14, 2018, 01:02 |
Uwe Pilz
Rep Power: 15 |
There is a setfields command in the allrun file. Check that.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
April 16, 2018, 15:49 |
Robbe
Rep Power: 8 |
Hi Uwe
Thanks for your answer. That did the trick! Could you (or someone else) please elaborate a bit on the meaning of the setFieldsDict file? If I understand correctly, I have already set the initial value of the field in the T file, so why exactly do I need to specify it again? Also, why don't the pressure and velocity need such an additional entry in setFieldsDict? Thanks again. Robbe |
April 17, 2018, 00:12 |
Uwe Pilz
Rep Power: 15 |
Setfileds is not necessary in closer sense. You may always set the filed in the 0/T file in your example.
Setfields hels to set a filed independend from te mesh. If you use a finer mesh, simply by changing some hex commands, a Code:
value nonuniform List<scalar>
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
