April 29, 2018, 19:22 |
Temperature Equation in interFoam
Cláudio Corrêa
Rep Power: 8 |
I'm doctoral student in Brazil and my reasearch is related with turbulent flow in vertical pipe. I'm using OpenFoam and solver interFoam with addition Temperature but I have problems with simulation because the formulation of the temperature equation is not correct, I guess. In attached follow the file reffering to the temperature equation.
To make the change I followed the template of Damiano Natali. My simulation of 3D dambreak case it's bad, the temperature is dimmishing in time. Can you help me? TEqn.H |
April 30, 2018, 07:53 |
#2 | |
Ricky
Rep Power: 11 |
Hallo,
Please refer to this book, here the implementation of Temperature equation in interFoam is precisely explained. hope this helps! Regards, Ricky Quote:
If it is easy, then something is fishy! |
April 30, 2018, 09:48 |
Cláudio Corrêa
Rep Power: 8 |
Hello Rick,
Thanks for the book's nomination. It will be very helpful in developing my research. |
Adding temperature equation to porousSimpleFoam | David_010 | OpenFOAM Programming & Development | 9 | February 14, 2018 01:22 |
SimpleFoam and Temperature Equation | Pat84 | OpenFOAM Running, Solving & CFD | 5 | June 16, 2014 00:43 |
Adding temperature equation to twoPhaseEulerFoam | nikhil5490 | OpenFOAM Programming & Development | 0 | April 30, 2014 13:28 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
Add passive scalar temperature equation to the Channelflow | YANGLIANG | OpenFOAM Running, Solving & CFD | 1 | March 9, 2010 05:23 |
