Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
interFoam - validation for bubble/droplet flows in microfluidics
Like Tree39Likes
Old   October 3, 2013, 08:36
Default interFoam - validation for bubble/droplet flows in microfluidics
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
Dear all,
It is a bit ashamed but I would like to share one of our work on the validations of interFoam, titled "Benchmark numerical simulations of segmented two-phase flows in microchannels using the Volume of Fluid method". In this work, we presented three benchmark cases - the steady motion of bubbles in a straight two-dimensional channel, the formation of bubbles in two- and three-dimensional T-junctions, and the breakup of droplets in three-dimensional T-junctions - and provided guidelines to set appropriate numerical settings for a simulation of microbubble/microdroplet flows.
Please find here the link to the paper: http://dx.doi.org/10.1016/j.compfluid.2013.06.024
If you can not download the paper, I am more than happy to send you a copy of it.
With best regards,
Duong
wyldckat, ageorg, akidess and 15 others like this.
duongquaphim is offline   Reply With Quote
Old   October 4, 2013, 12:52
Kent Wardle
kwardle is on a distinguished road
No need to be ashamed. Thanks for sharing!
-Kent
duongquaphim likes this.
kwardle is offline   Reply With Quote
Old   January 9, 2014, 11:14
alighaffari
alighaffari is on a distinguished road
Hi Dear Duong
Thanks for your good paper.
I am new in interFoam. I have two simple questions.
1) how can we apply the smoother function (Eq.9 in your paper) in our problem? I think it can be set: system/fvSolution dictionary, PISO loop subsection was set with m corrections (nCorrectors)
is it true?
2) where should be determined the value of adjustable coefficient "Cγ in Eq.7"?
Thanks
Ali
mizzou likes this.
alighaffari is offline   Reply With Quote
Old   July 11, 2014, 03:32
Bin Xu
norkistar is on a distinguished road
Could you please share the case setup for openfoam? Best regards
Multiphase Mikal likes this.
norkistar is offline   Reply With Quote
Old   January 28, 2015, 16:02
Duong A. Hoang
Dear all,
I just got a bit of free time lately to reorganize my data. Here you can find the code and the test cases I have run for my validation. Please be aware that all these validations have been performed with OF-1.6-ext.
Best regards,
Duong
Old   February 17, 2015, 04:06
Pierre HORGUE
Pedro24 is on a distinguished road
I'm not sure but I think that the function fvc::average already exists and do the same operation as your "smooth function".
In the OpenFOAM C++ doc, you can read:
volField = fvc::average(SurfaceField)
Area-weighted average a surfaceField creating a volField.
So you can do your smoothing by :
alpha_smoothed = fvc::average(fvc::interpolate(alpha));
Regards,
Pierre
Pedro24 is offline   Reply With Quote
Old   February 17, 2015, 05:15
Duong A. Hoang
Originally Posted by Pedro24 View Post
Regards,
Pierre
Indeed you can also use that function. And it is much simpler I agree.
At the time I implemented that, I would like to have controls on the level of smoothing (averaging) and also to be able to implement different smoothers (which I did not find superior to that simple Laplacian). So that's why you have such a piece of code.
Best,
Duong
Old   September 30, 2015, 02:43
Sripadaraja
Sripadaraja is on a distinguished road
Hi Duong,
I just downloded your file (bubble_generation). I am able to blockMesh.
Check topology
Basic statistics
Number of internal faces : 44
Number of boundary faces : 56
Number of defined boundary faces : 56
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list
Further when I run "interFoam" solver I get this error.
paramesh@HP-WS3:~/OpenFOAM/paramesh-2.4.0/run/tutorials/incompressible/pimpleFoam/bubble_generation$ interFoam
| \\ / O peration | Version: 2.4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.4.0-f0842aea0e77
Exec : interFoam
Date : Sep 30 2015
Time : 12:12:41
Host : "HP-WS3"
PID : 10778
Case : /home/paramesh/OpenFOAM/paramesh-2.4.0/run/tutorials/incompressible/pimpleFoam/bubble_generation
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
--> FOAM FATAL IO ERROR:
keyword PIMPLE is undefined in dictionary "/home/paramesh/OpenFOAM/paramesh-2.4.0/run/tutorials/incompressible/pimpleFoam/bubble_generation/system/fvSolution"
file: /home/paramesh/OpenFOAM/paramesh-2.4.0/run/tutorials/incompressible/pimpleFoam/bubble_generation/system/fvSolution from line 55 to line 132.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 648.
FOAM exiting
What is the problem?
-Sripad
Sripadaraja is offline   Reply With Quote
Old   October 12, 2015, 02:28
akidess's Avatar
Anton Kidess
That's the problem. As Duong stated the case setup is for OF-1.6. You'll need to update the dictionaries for 2.4.0. Compare the case with the tutorial cases and you will fix the error quickly.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   December 16, 2015, 04:02
Sripadaraja
Akidess. I notice the next error
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
cannot find file
file: /home/paramesh/OpenFOAM/paramesh-3.0.0/run/tutorials/multiphase/interFoam/bubble_generation_trial/0/p_rgh at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Old   December 16, 2015, 04:59
akidess's Avatar
Anton Kidess
You are missing the file p_rgh. Please have a look at the interFoam tutorials.
Old   August 10, 2016, 06:56
Devdutt Sharma
DevD_10 is on a distinguished road
hey.. do you still have these files?
I wanted to download them and i am unable to get the files from this link
Problem solved, able to download now.
Last edited by DevD_10; August 10, 2016 at 07:11. Reason: Problem solved, able to download now.
DevD_10 is offline   Reply With Quote
Old   December 18, 2016, 15:15
abdikerim kurbanaliev
kerim is on a distinguished road
Could you please share the copy of your paper? Best regards
kerim is offline   Reply With Quote
Old   April 20, 2017, 10:35
Peter Favreau
pfavreau is on a distinguished road
Dear all,
Best regards,
Duong
I tried to update your solver to run on OpenFOAM 4.1. Unfortunately, I have obtained so much errors... Did you adapt your code to this version of OpenFOAM ? How can I achieve that ?
Best Regards,
Peter.
pfavreau is offline   Reply With Quote
Old   May 2, 2017, 03:11
Duong A. Hoang
I think that it should be quite straightforward to adapt/implement the Laplacian solver in interFOAM version. However, I did not work on this topic for a while, so I do not know any details to tell you. The only thing I could think about is the difference in library name and the change of alpha field.
Duong
Old   May 19, 2017, 10:22
Peter Favreau
Thank you for the reply. I will try to update the solver, if someone is interested by this update, please contact me, I will share.
Best regards,
Peter
Old   May 24, 2017, 05:37
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Best regards,
Peter
Have a look at the following.
OF-4.x implementation of 'vofsmooth':
I have implemented Duong's "vofsmooth" in OF-4.x.
It was implemented using OF's run-time selection mechanism and a dynamic library trick, such that it should work with any solver (that uses OF's libinterfaceProperties.so: inter(DyM)Foam, compressibleInter(DyM)Foam, multiphaseInter(DyM)Foam, interPhaseChange(DyM)Foam and very likely some more.)
[Disclaimer: I have only tried inter(DyM)Foam in my work.]
See the README.md on GitHub:
https://github.com/floquation/OF-kva...faceProperties
rasool_soofi likes this.
floquation is offline   Reply With Quote
Old   June 21, 2017, 05:18
Peter Favreau
Thanks a lot for sharing your code :-)
Best regards,
Peter
Old   June 21, 2017, 09:30
Peter Favreau
It's weird, but when I compile your code it works. Bun when I'm running the damBreak case, it returns the following error :
Selecting incompressible transport model Newtonian
Selecting curvatureModel vofsmooth
kva: curvatureModel::read(vofsmooth);
kva: curvatureModels::vofsmooth::read();
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
Erreur de segmentation (core dumped)
Any idea ??
Old   June 21, 2017, 10:38
floquation's Avatar
Kevin van As
That had certainly puzzled me for some time as well, because the code is correct... However, since I am a self-educated fool (which I bet most of us are) whose messing with dynamic libraries, I was only thinking in terms of code. But although there is nothing wrong with the code, I did mess up the binary-compatibility, as I didn't know that any such thing (ABI) existed.
I am working on a proper "fix", which I should have soon. (That is, I should regain the binary-compatibility.) For the time being, you can easily work around this, as I described right here:
https://github.com/floquation/OF-kva...rties/issues/2
That solution boils down to recompiling your solver; or rather compiling a clone of your solver that is linked against my library.
Setting BCs for Riverine Flows using Interfoam kflora OpenFOAM Running, Solving & CFD 38 July 27, 2022 06:51
CFX problem in ubuntu (linux) Vigneshramaero CFX 0 July 13, 2012 10:22
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 00:52
validation for densely packed channel flows shefali Main CFD Forum 1 February 8, 2011 03:35
Validation tests for 3-D flows Alexey Main CFD Forum 1 January 5, 2000 23:48
