Is actuatorDisk fvOption reliable? (ESI-OpenFOAM) |
September 26, 2023, 05:12 |
#1 | ||
Marķa Rosales
Rep Power: 3 |
Hello all!
I found that actuatorDisk-fvOption gives low deficit in velocity when simulating a single windturbin in flat terrain, taking in consideration the ABL B.C. Maybe, it comes from a bad input of information in fvOption dictionary. I have not found thesis or papers that uses this tool that comes with openfoam, so I don't have a reference if my inputs are ok or if this tool is trully reliable... My case: Stream flow goes in +x, the 'y' is spanwise axis and 'z', vertical. My windTurbine is 80 m diameter, its hub height is 80 m, and it's hub-centre is located at P1(500,640,80)m. This case actuator is a SINK. I don't have the curve of cp or ct but I know the values of them for Uhub, that's why I entry them as a constant: Quote:
I appreciate any comments about this tool or other solutions to approach wind turbine simulation via AD method in openfoam. Thanks! |
October 24, 2023, 13:19 |
Will Kernkamp
Rep Power: 12 |
The disk area should be pi/4*80^2 is about 4800.
actuatordisk, fvoption, openfoam, wind, wind turbine |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Is OpenFoam really reliable? It is Urgent!!! | Technoyoungman | OpenFOAM Running, Solving & CFD | 8 | November 9, 2011 22:41 |
