how to mesh a cylinder fixed in water tank
Old   April 23, 2012, 20:09
Default how to mesh a cylinder fixed in water tank
llh
lilinghan8 is on a distinguished road
hi,
I would to add a cylinder(fixed) in the middle of a wave tank, how to do the mesh generation?
I learned from tutorial "flow around a cylinder" http://www.foamcfd.org/Nabla/guides/...Guidese12.html
and divided the tank into 20 blocks.
The first problem is about "inequality of cells number between neighbour blocks" I dont quite understand about how to set the red part of each block, the order or the numbers after it:
hex (4 9 10 5 23 28 29 24) (100 20 50) simpleGrading (1 1 1)
The second problem is after mesh generation (I just set all the numbers of cells in each direction equals the same) I use waveFOAM to generate wave and finally I got floating point exception issue, i am not sure if it is caused by wrong mesh generation, is there any way to solve it?
Regards,
Vricc
lilinghan8 is offline   Reply With Quote
Old   April 24, 2012, 02:11
kid
cfdkid
kid is on a distinguished road
Would you like to take another approach of importing "cylinder.STL" file and meshing around it , instead of generating the way described in above link ? ( Mostly this is approach i take!! )
________________________________________
Regards,
CFDkid
It never gets easier You just get Better
kid is offline   Reply With Quote
Old   April 24, 2012, 03:37
llh
Originally Posted by kid View Post
hi,
Thanks for ur reply,Could you link me a tutorial about your approach since I am fresh to cfd software and have no idea what is "cylinder.STL".
Many thanks
Vricc
Old   April 24, 2012, 03:59
kid
cfdkid
Ok
Do you have geometry modeling software.
"cylinder.stl" It is just a name , it can be a cylinder generated using geometry modeling software.
"xyz.stl" here stl is a format in which a given geometry could be imported in OpenFOAM.
So my question is again do u have modeling s/w?
Regards,
CFDkid
Old   April 24, 2012, 04:06
llh
Ok
No, I don't have any.
Old   April 24, 2012, 04:14
kid
cfdkid
Then get one .
"Salome" is a free-ware.
Then we can discuss.
Here is a image of your case generated in OpenFOAM.
Regards,
CFDkid
Old   April 24, 2012, 05:26
llh
Then get one .
Thanks for your information,
Btw, could you send me the original file of this image and how to combine this with blockMeshDict in openfoam?
Regards,
Vricc
Old   April 24, 2012, 07:27
kid
cfdkid
@ llh
Yes, why not find a sample case.
Here
http://db.tt/Fsn0siFa
Note: make suitable changes for your case.
Regards,
CFDkid
Old   April 24, 2012, 08:36
llh
Thanks again for you help
Old   April 24, 2012, 18:26
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Simple geometries such as this one can be also generated using paraview-->sources, then use the triangulate filter and then save data to save as a .stl
Anyway seems like you are having problems even with blockMesh, I would suggest you to read at least the first part of the openFoam manual before doing anything else…
lovecraft22 is offline   Reply With Quote
Old   April 30, 2012, 11:49
Björn Windén
Location: National Maritime Research Institute, Tokyo, Japan
winden is on a distinguished road
If you will be using snappyHexMesh to get the mesh around the cylinder you don't need an stl, just use searchableCylinder.
//Björn
winden is offline   Reply With Quote
What is best mesh for cylinder tube? olivia FLUENT 7 January 16, 2014 05:55
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
