August 21, 2017, 02:13 |
ElmerFoamFSI parallel error
Thaw Tar
Rep Power: 13 |
I am not very sure that my post is directly related to OpenFOAM but I would be very grateful if anyone could help me.
I want to do FSI with large deformations and chose ElmerFoamFSI for my research. ElmerFoamFSi is a package intended to solve fluid-structure interaction problems using OpenFOAM and Elmer. It couples foam-extend 3.2 and Elmer 8.0 by something called IMPACT coupler (I don't know the details). I could compile ElmerFoamFSI with the default BuildSourceScript file and I could run the test cases such as SimpleDynamic and HronTurek FSI3 cases using a single thread. However, when I try to run in parallel using "elmerfoamfsiPar" solver using "elmerfoamfsiPar test.config" I got the following message: elmerfoamfsiPar:Run: User Parameters: elmerfoamfsiPar:Run: FluidSolver = OpenFoamFSI elmerfoamfsiPar:Run: SolidSolver = ElmerCSC elmerfoamfsiPar:Run: TransferService = SurfX elmerfoamfsiPar:Run: FinalTime = 1.0 elmerfoamfsiPar:Run: TimeStep = 1.0e-3 FsiFoam:Load: Loading FsiFoamModule with name FluidsComponentInterface. Loading ElmerCSC: StructuresComponentInterface elmerfoamfsiPar:fsicouplingpar:Initialize: Final Time = 1 elmerfoamfsiPar:fsicouplingpar:Initialize: Time Step = 0.001 OF Module verbosity = 1 -------------------------------------------------------------------------- Calling MPI_Init or MPI_Init_thread twice is erroneous. -------------------------------------------------------------------------- [thawtar-Workstation:8494] *** An error occurred in MPI_Init [thawtar-Workstation:8494] *** on communicator MPI_COMM_WORLD [thawtar-Workstation:8494] *** MPI_ERR_OTHER: known error not in list [thawtar-Workstation:8494] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort I think my OpenMPI interface is working well because I can run foam-extend-3.2 cases in parallel well. I do not know how to fix this error. I would be very grateful if you can help me solve this problem. |
September 10, 2017, 08:38 |
Solved that part
Thaw Tar
Rep Power: 13 |
It was my stupid mistake.
I tried serial solver using "mpirun -np 4 elmerfoamfsi test.cfg" and it did not work because it was intended for only serial computation. The parallel version is elmerfoamfsiPar and it needs mpirun. So, I tried "mpirun -np 4 elmerfoamfsiPar test.cfg" And it works!! Cheers! |
October 30, 2017, 16:46 |
Shyam Sunder
Rep Power: 10 |
Hello Tar
I ran the parallel case as you described, but still i am getting MPI error. Following is what I did and what I am getting: mpirun -np 2 elmerfoamfsiPar test.config elmerfoamfsiPar:Run: User Parameters: elmerfoamfsiPar:Run: FluidSolver = OpenFoamFSI elmerfoamfsiPar:Run: SolidSolver = ElmerCSC elmerfoamfsiPar:Run: TransferService = SurfX elmerfoamfsiPar:Run: FinalTime = 0.05 elmerfoamfsiPar:Run: TimeStep = 5.0e-4 FsiFoam:Load: Loading FsiFoamModule with name FluidsComponentInterface. FsiFoam:Load: Loading FsiFoamModule with name FluidsComponentInterface. Loading ElmerCSC: StructuresComponentInterface Loading ElmerCSC: StructuresComponentInterface elmerfoamfsiPar:fsicouplingpar:Initialize: Final Time = 0.05 elmerfoamfsiPar:fsicouplingpar:Initialize: Time Step = 0.0005 OF Module verbosity = 1 OF Module verbosity = 1 [cfd2:27055] *** An error occurred in MPI_Init [cfd2:27055] *** reported by process [139957580988417,139955804307457] [cfd2:27055] *** on communicator MPI_COMM_WORLD [cfd2:27055] *** MPI_ERR_OTHER: known error not in list [cfd2:27055] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, [cfd2:27055] *** and potentially your MPI job) I have decomposed the case using AllrunPar. Any clue what I am missing? Thanks Shyam |
October 30, 2017, 17:41 |
Thaw Tar
Rep Power: 13 |
I can see you use 2 processors. So, I think you decomposed into 2 domains in Open Foam.
But how about Elmer? Did you use the version for 2 processors ? May be you need 2 processors version of Elmer grid (I mean, the script for grid generation for Elmer). |
November 3, 2017, 12:25 |
Parallel ElmerFoamFSI
Shyam Sunder
Rep Power: 10 |
Hello Tar
Can you please help me in how to prepare the parallel ElmerFoamFSI case? Where I can further information on this? I am using the following commands but still getting error: 1) Run the script AllrunParDrvSetup 2) cd fluid 3) ElmerGrid 1 2 beam3d -partition 4 1 1 0 4) mpirun -np 4 elmerfoamfsiPar test.config The test case I am trying is located in ElmerFoamFSI/testing/share/Testing/test_data/HronTurekFSI3_136/ Thanks Shyam |
elmerfoamfsi, mpi_init, openfoam fsi |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
