Pressure Coefficient Cp
Old   September 13, 2011, 07:45
Post Pressure Coefficient Cp
kid
cfdkid
kid is on a distinguished road
For a 2D steady state, in-compressible "cylinder" flow Cp is calculated (OpenFOAM).
But when i try to plot it at all angles i am getting theoretical graph.
While i expect to get experimental graph.
Formula used for in-compressible Cp= 1- (Vo/Vinf)^2
Vo= Velocity at given theta
Vinf= Free stream Velocity
Please help, what should i do, to get graph matching to experimental Cp.
Cheers
CFDkid
kid is offline   Reply With Quote
Old   September 14, 2011, 00:49
Post
kid
cfdkid
helps guys
Old   July 21, 2012, 22:33
hfs
hfs is on a distinguished road
Hello!
Did you get any answers??
I have the same case!
Help please
Regards,,,
hfs is offline   Reply With Quote
Old   July 22, 2012, 06:05
niaz's Avatar
A_R
niaz is on a distinguished road
Dear kid
you mean that you write pressure around cylinder but you give result like theoretical?
can you explain more and show your pressure result?
in what manner do you write your result?
niaz is offline   Reply With Quote
pressure coefficient
Pressure coefficient Giuseppe FLUENT 2 July 26, 2015 03:19
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
Problem in Result of the pressure coefficient Ken Choi Main CFD Forum 2 March 15, 1999 04:15
