Please comment on this Results of Natural Convection!!!
Old   August 6, 2012, 08:06
Default Please comment on this Results of Natural Convection!!!
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Hi everybody,
I'm solving natural convection. the attached picture is the result of temperature. side walls are isolated (zeroGradient) and bottom wall temperature is at 400K and the ceiling temperature is 300K, the internal temperature is 350K. but I think this result isn't true.
please comment on this result, is it correct? if not, you think from where this result originates?
Thank you
adambarfi is offline   Reply With Quote
Old   August 6, 2012, 11:09
Nima Samkhaniani
nimasam is on a distinguished road
dear mostafa,
1) whats your substance?
air, water or ?????
2) which solver do you use?
3) whats the direction of gravity?
4) could you put velocity contour and velocity stream pic here too
nimasam is offline   Reply With Quote
Old   August 7, 2012, 04:42
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by nimasam View Post
dear mostafa,
air, water or ?????
Hi Nima,
1-air, 2-buoyantSimpleFoam 3-y direction (-9.81)
I changed my solver to buoyantBoussinesqSimpleFoam, fortunately, It solved. I guess that problem source was in thermophysicalProperties. this solver doesn't have transport properties dictionary.
but another question:
the side walls are isolated, in blockMeshDict do I use wall type for all of them or I should use wall type for two and empty type for other walls which they are opposite?
thank you
Old   August 7, 2012, 05:52
Nima Samkhaniani
However
1) buoyantBoussinesqSimpleFoam uses Boussinesq assumption means
(delta {rho})/{rho}<<1
if you have a big temperature difference maybe it is better to use buoyantSimpleFoam
2)it depends what you are going to solve, if you want to simulate heat transfer between to parallel surface, you can use (two empty (frontAndBack) and two symmetry plane (leftAndRight)) but if you want to simulate a box, you should consider all of them as wall, then for sidewall apply zeroGradient for T
Old   August 7, 2012, 08:01
adambarfi's Avatar
Mostafa Mahmoudi
However
Dear Nima,
Thanks a lot for your reply.
If I want to solve my problem with another fluid, in example a viscoelastic fluid, how should I modify the thermophysicalPeroperties (I mean thermoType)? I'm trying to write a viscoelastic solver and according it I want to solve natural convection.
Old   August 7, 2012, 09:29
Nima Samkhaniani
look at user guide last chapter, it tells you how to modified a thermophysicalPeroperties but i dont know it is appropriate for viscoelastic fluid or not, im not familiar with viscoelastic fluid at all,
but in general for non-newtonian flow, i think you can use buoyantBoussinesqSimpleFoam, and you just need to modify transport model from Newtonian to a non-newtonian type for example pawerlaw with appropriate coefficient in constant/transportproperties
Old   August 7, 2012, 12:06
adambarfi's Avatar
Mostafa Mahmoudi
Dear Nima,
my trouble is that the non-newtonian solver of OF is just power law, I want PPPT, Gesikes, Oldroyd A and B models. so I must write it and I'm trying.
again I run my model with buoyantSimpleFoam but again the same results obtained. have you any idea? but I think the density of a viscoelastic fluid doesn't depend on Temperature as deep as shear stress.
I attach you the velocity Glyph and a truncated velocity contour.
thanks a lot
Old   August 7, 2012, 13:24
Nima Samkhaniani
1) i guess those model are implemented in OpenFOAM-1.6.ext or 1.5-dev, so you may want to implement just energy equation to those models
2)you used no slip condition for all your wall, and distribution of velocity seems fine, whats wrong with result?
Old   August 7, 2012, 14:04
adambarfi's Avatar
Mostafa Mahmoudi
Dear Nima,
I think the temperature distribution isn't true. it doesn't similar to a natural convection at all. I check it with Fluent results. the temperature distribution according to the boundary conditions seems to be wrong.
as you see in the pictures that attached before, the velocity magnitude is very low, and in fact the convection didn't occur. what is your opinion?
Old   August 7, 2012, 15:53
Nima Samkhaniani
i dont know exactly, but test a case with these condition
1) high distance between two hot parallel plate (1 m)
2) increase deltaT
3)turn off turbulence
4)use slip condition or symmetryPlane for side walls and empty for frontAndBack
5)use bouyantPressure
i forget to ask you whether the simulation has been converged or not
Old   August 7, 2012, 15:58
adambarfi's Avatar
Mostafa Mahmoudi
2) increase deltaT
thank you Nima,
my last solution was converged.
I did what you said. the solution again was converged, and the results had features of natural convection. but I want to solve this in a box and this boundary condition, I think, doesn't true for it.
meanwhile, congratulation for the two Gold and two Silver Medals!!!!!
Natural Convection using Compressible Flow (chtMultiRegionFOAM) msarkar OpenFOAM 2 September 7, 2010 00:13
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 04:22
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
Approximate Mixing due to Natural Convection Greg Perkins Main CFD Forum 0 February 12, 2003 18:43
Nemerical results on natural convection Xi Man Main CFD Forum 0 September 28, 1999 10:49
