Floating point exception when runnning elasticThermalSolidFoam |
September 27, 2012, 12:34 |
Sangeeta
Hello everybody,
I am solving a 2D square block case where temperature is changing only in y direction with zero displacement field at time=0. I am using pre calculated temperature values and fvScheme are not calculating for ddt scheme. My mesh is 100X100. I have compiled elasticThermalSolidFoam solver for not calculation ddt scheme. When I am running my case it is showing following problem: Create time Create mesh for time = 0 Reading field U Patch bottomSurface Traction boundary field: U Patch right Traction boundary field: U max(detdd) = 2.75066e-32 min(detdd) = -1.11187e-48 average(detdd) = 2.32475e-33 max(detdd) = 2.75066e-32 min(detdd) = -6.84228e-49 average(detdd) = 2.33578e-33 nAddCells/nCells = 0.0198 Reading field T Selecting rheology model linearElastic Reading thermal properties Selecting thermal model constant surface method chosen for calculation of sigmaExp Calculating displacement field Time: 1 Solving for U using GAMG, residual = 1 Solving for U using GAMG, residual = 0.951875 Floating point exception Does anyone have any idea why this problem is coming and how to fix it? Thanks in advace. Best regards, Sangeeta |
September 27, 2012, 16:30 |
Sangeeta
Hello everybody,
I have solved the problem which I have mentioned above. I have changed my BCs and now it is working Best regards, Sangeeta |
No convergence; floating point exception all the time | Tobi | OpenFOAM | 2 | September 19, 2012 04:01 |
[blockMesh] error EOF in blockMesh | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 7 | May 17, 2012 00:37 |
MPI Error - simpleFoam - Floating Point Exception | scott | OpenFOAM Running, Solving & CFD | 3 | April 13, 2012 16:34 |
reactingFoam floating point exception | pajofego | OpenFOAM | 0 | November 6, 2010 17:29 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
