About moveDynamicMesh
Old   October 3, 2012, 09:46
Default About moveDynamicMesh
Samuele Z
samiam1000 is on a distinguished road
Dear Foamers,
I have seen a fantastic feature of Fluent. The mesh motion is possible through an automatice re-meshing. Let's say, for example, that I wanna open a door. I create a single mesh and then launch the simulation and the software first strech the cells and then - when the skewness reaches a certain values - the solver itself do a remeshing.
Is there something similar in OF? Or we have only a tool that stretch the mesh?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   October 3, 2012, 10:09
Sandeep Menon
deepsterblue will become famous soon enough
Yup. You can find it here:
https://github.com/smenon/dynamicTopoFvMesh
Sandeep Menon
University of Massachusetts Amherst
deepsterblue is offline   Reply With Quote
Old   October 3, 2012, 11:21
Samuele Z
That's nice.
How does this work? Is it downloadable?
Can you help?
I can be a good tester ..
Thanks,
Samuele
Old   October 3, 2012, 11:26
Sandeep Menon
The non-parallel bits are already part of OpenFOAM-extend.
With parallel functionality, you'll have to check it out from the repository. Installation instructions are here:
https://github.com/smenon/dynamicTop...er/Install.txt
I believe Kyle Mooney has already prepared documents / presentations on usage of the class at the recent OpenFOAM workshop, so if you go through the archives, you should find them there.
Sandeep Menon
Old   October 4, 2012, 04:40
Samuele Z
Can I share my case in order to understand if someone can help?
How can I do this?
moveDynamicMesh with dynamicMotionSolverFvMesh gfilip OpenFOAM Running, Solving & CFD 7 March 19, 2014 05:35
moveMesh vs. moveDynamicMesh samiam1000 OpenFOAM 2 May 31, 2012 10:22
moveDynamicMesh Sylvain OpenFOAM 13 November 10, 2011 23:22
moveDynamicMesh in parallel chrashes Arnoldinho OpenFOAM Bugs 18 May 19, 2011 13:57
moveDynamicMesh broken ? podallaire OpenFOAM Bugs 2 November 11, 2009 13:44
