Hydrostatic Pressure in a cube
Old   November 25, 2012, 07:20
Default Hydrostatic Pressure in a cube
andreas is on a distinguished road
Dear Foamers,
I would like to understand how to implement hydrostatic pressure on a wall. I am a beginner with OF.
For that, I created a simple cube mesh:
convertToMeters 1;
vertices
    (0 0 0)
    (0 0 1)
    (0 1 1)
    (0 1 0)
    (1 0 0)
    (1 0 1)
    (1 1 1)
    (1 1 0)
blocks
    hex (0 1 2 3 4 5 6 7) (40 40 40) simpleGrading (1 1 1)
edges
boundary
    walls
        type wall;
        faces
            (0 1 2 3)
            (4 5 6 7)
        (4 0 1 5)
        (5 6 2 1)
        (7 6 2 3)
        (4 7 3 0)
I want the hydrostatic pressure, so I used buoyantPressure for p:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    walls
        type            buoyantPressure;
    value        uniform 0;
The velocity type is pressureInletVelocity and the value is uniform(0 0 0).
I also created a g folder in "constant":
FoamFile
    version     2.0;
    format      ascii;
    class       uniformDimensionedVectorField;
    location    "constant";
    object      g;
dimensions      [0 1 -2 0 0 0 0];
value           ( 0 0 -9.81 );
The fluid is not supposed to move since it is a closed cube.
I don't know exactly what solver should I use but it seems that pisoFoam is ok.
So here is the fvSolution:
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0;
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
And for the fvSchemes, I used an existing one:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nu,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(HbyA) linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
Here are the TransportProperties:
nu              nu [ 0 2 -1 0 0 0 0 ] 0.01;
transportModel    Newtonian;
Here is the terminal response:
--> FOAM FATAL IO ERROR:
keyword div((nuEff*dev(T(grad(U))))) is undefined in dictionary "/home/ubuntu/openfoam/simu/cube/system/fvSchemes::divSchemes"
I don't know what model should I use for div((nuEff*dev(T(grad(U))))?
Or maybe it is a wrong solver for a simple case like that?
Thank you for your help!
andreas is offline   Reply With Quote
Old   November 25, 2012, 15:53
Florian
Horus is on a distinguished road
I don't know if pisoFoam is right solver for this kind of problem.
For the error message you posted, simple add this expression to the divSchemes dictionary or set a default entry, e.g.
divSchemes
    div((nuEff*dev(T(grad(U))))) Gauss linear;
Horus is offline   Reply With Quote
Old   November 26, 2012, 03:42
Thank you for your answer!
I added that line in the fvSchemes, as well as the
laplacian(nuEff,U)    Gauss linear corrected;
in the laplacianSchemes.
Still, the terminal doesn't find the "g" folder:
--> FOAM FATAL ERROR:
    request for uniformDimensionedVectorField g from objectRegistry region0 failed
    available objects of type uniformDimensionedVectorField are
0
Where is the objectRegistry region0?
I tried to copy/paste the g in all the folders (0,constant,system) still doesn't work.
Thanks for your help!
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
vof + hydrostatic pressure ariorus FLUENT 0 August 7, 2009 10:57
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
hydrostatic pressure in bouyant flow Atit CFX 3 May 31, 2006 07:38
