Example of pdfPlot
Like Tree3Likes
  • 3 Post By wyldckat
Old   February 23, 2013, 12:22
Default Example of pdfPlot
Mahdi Hosseinali
anishtain4 is on a distinguished road
Dear Foamers,
I think there has been a rare part of you who has been used this utility, but those how did: please let me know how should I do it?
I have found a sample pdfDict in github and copied it to my constant folder, yet still openFoam complains:
keyword type is undefined in dictionary "address"
file: /media/FreeAgentGoFlexDrive/Mahdi/pimple_32x32_albada/constant/pdfDict from line 18 to line 27.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 400.
banana trick does not work here, can anyone give me a guide please?
anishtain4 is offline   Reply With Quote
Old   February 23, 2013, 17:11
Retired Super Moderator
Bruno Santos
Greetings Mahdi,
Interesting... lets see if I can figure it out...
  1. You can find an example in OpenFOAM's source code at:
    $FOAM_APP/utilities/postProcessing/miscellaneous/pdfPlot/pdfDict
  2. I've used the tutorial "incompressible/pimpleFoam/TJunction" as reference.
  3. Ran the tutorial:
    blockMesh
    pimpleFoam
  4. Placed the "pdfDict" from the location above into the folder "constant".
  5. Ran pdfPlot.
  6. A few errors were detected and the fixed file seems to be:
    |  \\    /   O peration     | Version:  2.1.x                                 |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      pdfDict;
    // Number of intervals/bins in pdf plot
    nIntervals      20;
    // Number of samples
    nSamples        10000;
    // Type of pdf
    type         RosinRammler;
    // Write data flag
    writeData       true;
    // PDF model coefficients
    RosinRammlerDistribution
        minValue        1e-06;
        maxValue        200e-06;
        d               60.0e-06;
        n               0.8;
  7. The results were placed in the folder "pdf":
    RosinRammler.data
    RosinRammler.xy
  8. From what I can understand, the XY values is the actual PDF and the data file is the sample used...
I'll report the bug on the "pdfDict" file in a few moments...
edit: reported as http://www.openfoam.org/mantisbt/view.php?id=754
Best regards,
Bruno
Old   February 24, 2013, 01:49
Mahdi Hosseinali
Unfortunately that did not do the trick for me.
I found out that there is an extra - there and you can find all the types in distributionModel.H, but still I'm getting the same error. Even for the pimple case you just mentioned which depicts something should be wrong with my openFoam not the case setup or pdfDict.
I tried rebuilding it but no point either
Old   February 24, 2013, 15:13
Bruno Santos
Hi Mahdi,
I had forgotten to test the previous steps with OpenFOAM 2.1.1. Nonetheless, I've tested them now and it all worked as intended.
Perhaps you modified something directly in OpenFOAM's source code? If you have, then I suggest that you also install OpenFOAM 2.1.x (as a personal installation, not as a global installation ) and learn how to use git, which will aid you in keeping track of changes you make to the source code!
Or you can use a personal installation of OpenFOAM 2.1.1 and use git on it... that would work as well.
As for having more than one installation of OpenFOAM on your machine, check this blog post of mine: http://www.cfd-online.com/Forums/blo...vironment.html
Best regards,
Bruno
Old   July 5, 2018, 07:06
Default But the pdf of which variable ?
gned
gned is on a distinguished road
Ok wyldcat, but of which field variable this pdfPlot does the pdf in postpro? and how to specify a different variable in OF5?
gned is offline   Reply With Quote
pdfPlot , probability density funktion , pdf , pdfDictionary heavy_user OpenFOAM Post-Processing 2 October 15, 2010 08:06
