adding layer in dynamic mesh.
Old   March 14, 2013, 10:16
Default adding layer in dynamic mesh.
Vadims Geza
Vadims.geza is on a distinguished road
Hi all Foamers,
Have been using OpenFOAM quite long time, but only now faced with mesh motion.
The problem I would like to solve is similar to SnakeRiverCanyon tutorial (which does not work on my OF-1.6-ext, but I tried it on OF-2.1) - the block with one patch where nonuniform motion is prescribed using dynamicMotionSolverFvMesh. Works fine, but after some time the cell aspect ratio gets really large. My first idea was to add layers, but from all available options, none of them seems to fit.
I would appreciate any suggestion for using existing options from topoChangerFvMesh, or any hint about which of them is most similar to my needs, so that I can modify it myself!
Thanks,
Vadims
Vadims.geza is offline   Reply With Quote
Old   March 14, 2013, 13:44
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
If you are willing to put in the time, learning how to use the layerAdditionRemoval mesh modifier can help you out. I've posted bug reports in Mantis and several threads here related. Also have a look at the 1.6-ext engineTopoChanger meshes, as that is the only place I have seen the modifers implemented.
mturcios777 is offline   Reply With Quote
[snappyHexMesh] Troubles with layer adding in my mesh Pierre.c OpenFOAM Meshing & Mesh Conversion 11 June 21, 2019 11:18
Dynamic mesh and boundary layer CCarl FLUENT 1 August 9, 2013 02:39
[snappyHexMesh] snappy hangs while layer generation bastil OpenFOAM Meshing & Mesh Conversion 3 October 29, 2010 07:19
Dynamic Mesh with Boundary Layer Marcell FLUENT 0 March 11, 2009 08:40
Add a layer of cells, dynamic mesh or ...? Modisa FLUENT 1 March 12, 2007 02:01
