adjusttimestep led to extremely small timestep
Like Tree4Likes
  • 2 Post By olivierG
  • 2 Post By fredo490
Old   May 28, 2013, 04:47
Default adjusttimestep led to extremely small timestep
kkpal is on a distinguished road
dear all
I'm simulating flow around an inclined cylinder at Re=3900 with pimpleFoam. I set my maxCo to be 1 and after some iterations, deltaT became very very small which made the simulation unable to progress. This warning even came out.
Courant Number mean: 0.00965307 max: 0.959928
deltaT = 3.9084e-11
--> FOAM Warning :
    From function Time::operator++()
    in file db/Time/Time.C at line 1029
    Increased the timePrecision from 9 to 10 to distinguish between timeNames at time 0.0417741
Before this I did several cases involving flow around non-inclined cylinder at Re=3900, it worked out fine; I also simulated flow around inclined cylinder at Re=100, it was also good.
Does someone else encountered with this problem before?
kkpal is offline   Reply With Quote
Old   May 28, 2013, 05:40
Olivier
olivierG is on a distinguished road
hello,
This mean that you have high non physical velocity somewhere. Check your boundary conditions (k & epsilon with bad initial guess ?) and your fvScheme (you may switch to Gauss upwind at the beginning).
regards,
olivier
kkpal and Ethon like this.
olivierG is offline   Reply With Quote
Old   May 28, 2013, 07:50
HECKMANN Frédéric
fredo490 is on a distinguished road
This is common if you use a uniform initialization of your problem. The initial solution is too different from your final solution, therefor the simulation must go through some crazy steps that leads to your "divergence".
You can try to run first with a fixed time step and once an approximate flow field is catch, you can turn to an adaptive time stepping.
Another solution is to initialize your case with a steady state solution (from SimpleFoam for example). Attention, potentialFoam will not give you a good initialization as the boundary layer is not included. Therefor you might get the same "divergence" problem.
fredo490 is offline   Reply With Quote
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 03:15
Small timestep make the simulation not converge Anna Tian CFX 1 August 7, 2012 19:25
How small to choose the timestep? kriskerst OpenFOAM Running, Solving & CFD 0 February 21, 2011 14:47
SIGFPE unless deltaT extremely small omican OpenFOAM 0 July 2, 2010 02:16
InterFoam very small timestep unoder OpenFOAM Running, Solving & CFD 12 November 27, 2005 07:47
