Cl(f) and Cl(r) what it means?
Like Tree4Likes
  • 1 Post By hhh
  • 3 Post By wyldckat
Old   June 13, 2013, 08:35
Default Cl(f) and Cl(r) what it means?
hhh
kunar
hhh is on a distinguished road
hai friends,
I am doing 2d airfoil analysis, i have doubt about the result i got ie Cl(f) and Cl(r) it means what? and also i mention in red colour
|  \\    /   O peration     | Version:  2.1.0                                 |
Build  : 2.1.0-0bc225064152
Exec   : simpleFoam
Date   : Jun 11 2013
Time   : 14:42:35
Host   : "ubuntu"
Case   : /home/toshiba/OpenFOAM/toshiba-2.1.0/run/tutorials/incompressible/simpleFoam/ku/airFoil2D
nProcs : 1
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model SpalartAllmaras
SpalartAllmarasCoeffs
    sigmaNut        0.66666;
    kappa           0.41;
    Cb1             0.1355;
    Cb2             0.622;
    Cw2             0.3;
    Cw3             2;
    Cv1             7.1;
    Cv2             5;
No field sources present
SIMPLE: convergence criteria
field p     tolerance 1e-05
    field U     tolerance 1e-05
    field nuTilda     tolerance 1e-05
Starting time loop
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 0.999993, Final residual = 0.0558381, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0760732, No Iterations 2
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0991895, No Iterations 39
time step continuity errors : sum local = 0.00119979, global = 6.26709e-16, cumulative = 6.26709e-16
smoothSolver:  Solving for nuTilda, Initial residual = 0.999999, Final residual = 0.0701398, No Iterations 4
ExecutionTime = 36.7 s  ClockTime = 37 s
forces output:
    forces(pressure,viscous)((257697 5.20299e+06 7.66604e-16),(6.53254 1.33905 -1.89121e-21))
    moment(pressure,viscous)((-3.39084e-17 -1.06156e-16 2.50963e+06),(4.47879e-23 -2.14236e-22 0.66735))
forceCoeffs output:
    Cm    = 901.996
    Cd    = 415.85
    Cl    = 1857.68
    Cl(f) = 1830.84
    Cl(r) = 26.8427
Time = 2
smoothSolver:  Solving for Ux, Initial residual = 0.623192, Final residual = 0.0517858, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 0.445407, Final residual = 0.0284221, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.711508, Final residual = 0.0608906, No Iterations 11
time step continuity errors : sum local = 0.000802196, global = 1.48748e-15, cumulative = 2.11418e-15
smoothSolver:  Solving for nuTilda, Initial residual = 0.258696, Final residual = 0.0187245, No Iterations 4
ExecutionTime = 45.88 s  ClockTime = 46 s
forces output:
    forces(pressure,viscous)((168327 3.88357e+06 2.72499e-16),(23.6262 2.65695 -2.24632e-21))
    moment(pressure,viscous)((-2.10668e-17 -5.5126e-17 1.89813e+06),(5.34685e-23 -6.75307e-22 1.37948))
forceCoeffs output:
    Cm    = 682.213
    Cd    = 301.9
    Cl    = 1385.1
    Cl(f) = 1374.76
    Cl(r) = 10.3358
please guide me
apu111 likes this.
Last edited by wyldckat; June 15, 2013 at 15:17. Reason: Added the [CODE] delimiters
hhh is offline   Reply With Quote
Old   June 15, 2013, 15:34
Retired Super Moderator
Bruno Santos
Hi Kumar,
Most of these you can find out about them by using Google. For example, use the following text in Google:
openfoam "fileModificationChecking"
Some of the more complicated ones to find, I'll try to explain:
  • "nProcs : 1" - indicates the number of cooperative processes being used for this case. Only when used in parallel, will you see this value increase.
  • Code:
    forceCoeffs output:
        Cm    = 682.213
        Cd    = 301.9
        Cl    = 1385.1
        Cl(f) = 1374.76
        Cl(r) = 10.3358
    These are calculated because in "system/controlDict" you are using the "forceCoeffs" function object. If you look at the file given by the following command:
    echo $FOAM_SRC/postProcessing/functionObjects/forces/forceCoeffs/forceCoeffs.C
    Or look at the one available online: https://github.com/OpenFOAM/OpenFOAM.../forceCoeffs.C
    You'll see the following code:
                coeffs[0] = (totForce & liftDir_)/(Aref_*pDyn);
                coeffs[1] = (totForce & dragDir_)/(Aref_*pDyn);
                coeffs[2] = (totMoment & pitchAxis_)/(Aref_*lRef_*pDyn);
                scalar Cl = sum(coeffs[0]);
                scalar Cd = sum(coeffs[1]);
                scalar Cm = sum(coeffs[2]);
                scalar Clf = Cl/2.0 + Cm;
                scalar Clr = Cl/2.0 - Cm;
    Which should be somewhat self-explanatory...
Best regards,
Bruno
apu111, anon_q and EddySouth like this.
Old   June 16, 2013, 05:32
hhh
kunar
Thanks Bruno for your kind response.
For laminar case
1. I remove nut & nu from O folder and i change p & U and in system folder
for i make changes in controldict according to my velocity
2.I didnt change in transport Properties in constant folder
3. RASProperties
RASModel SpalartAllmaras; [instead of
SpalartAllmaras i
change laminar]
turbulence on; [turbulence off]
printCoeffs on;
I think this is correct,if any thing i have to make changes,please let me know. my Reynolds number is 1000
once again thanks Bruno, you are coming forward to help me a lot
Thanks for your valuable time
Old   June 16, 2013, 08:55
Bruno Santos
Hi Kumar,
It seems to be OK for running in laminar flow.
All other configurations that were meant for turbulence in "system/fvSolution" and "system/fvSchemes", won't be used either way, so there is no need to remove them from those two files.
Best regards,
Bruno
Old   June 17, 2013, 03:08
hhh
kunar
Hai Bruno thanks a lot for your help, everything works fine.
I forgot to ask for turbulent case,while doing angle of attack 10. I set x velocity and y velocity in internal field in O folder for U
dimensions [0 1 -1 0 0 0 0];
internalField uniform (2.2946 0.4046 0);
boundaryField
inlet
type freestream;
freestreamValue uniform (2.2946 0.4046 0);
outlet
type freestream;
but I took default value for nuTilda and nut ie .14 whatever in that folder.
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0.14;
boundaryField
inlet
type freestream;
freestreamValue uniform 0.14;
outlet
type freestream;
I think it seems unimportant nut & nuTilda.Actually what i understand is the internal field value is to set the same as the inlet value( velocity= 2.33 m/s)but Anyhow it will be overwritten after the first time step.
This is correct or wrong,please let me know.
Old   June 17, 2013, 17:04
Bruno Santos
Hi Kumar,
Yes, if I remember correctly, "nut" and "nuTilda" are mostly calculated by the turbulence models. The set-up of the boundary conditions for those fields is almost just a formality, in the sense that they will be calculated if they are allowed to do so.
If I'm not mistaken, if you were to set one of the conditions in "nut" or "nuTilda" to zero gradient, such as this:
     inlet
        type zeroGradient;
It would still be zero gradient in the next step... assuming of course that the solver doesn't complain about this.
Another example is the "symmetry" type of condition, which the solver should allow, e.g.:
     symmetricWall
        type symmetry;
Best regards,
Bruno
PS: Have a look into the post the second link in my signature links to, because in it I explained how you can paste code
Old   June 18, 2013, 02:46
hhh
kunar
Thanks Bruno, Have a nice Day
Old   June 18, 2013, 05:55
hhh
kunar
Hai, Bruno
I am trying to do 3D wing Analysis for Unsteady case.I took NACA0012 airfoil and extrude 5cm length from Back Face of Domain.let Reynolds number 1000 and velocity is 3m/s.
DOMAIN
Boundary Condition
Side 1- velocity inlet
Side 2-pressure outlet
Top,Bottom,Front Face-symmetry
Back Face & wing - Wall
I did meshing part in gambit.
I want to flap the wing up & down for [-5 to +5 Amplitude angle]. For this I want to see the lift and Drag. Somebody did in Fluent (Dynamic Mesh), the same thing I want to do in open foam, please see the link its you tube video (ie Flapping 3d wing -Pressure contours).
LINK: [ http://www.youtube.com/watch?v=RjwV8TzW6a8 ]
For domain, Please see the attached my image for your reference.If you have any idea, please give me your suggestions.
Thanks for your valuable Time
[Other] Failed 1 mesh check camoesas OpenFOAM Meshing & Mesh Conversion 26 April 4, 2018 18:53
kEpsilon divergence s.m OpenFOAM Running, Solving & CFD 0 May 27, 2013 09:30
