logarithmic profile velocity - inlet BC
Old   June 14, 2013, 09:58
Unhappy logarithmic profile velocity - inlet BC
Pedro Ramos
pedroxramos is on a distinguished road
Hello Openfoamers,
I want to define a logarithmic velocity profileto my open channel flow (like this:
What do you suggest? Groovy BC? I have some problems to install it with OF 2.0.
There is a simpler way?
Best regards,
pedroxramos is offline   Reply With Quote
Old   June 14, 2013, 15:06
Lieven
Lieven will become famous soon enough
If you are working with a RANS turbulence model, you should be able to use the atmBoundaryLayerInletVelocity which simply imposes the logarithmic velocity profile.
Cheers,
L
Lieven is offline   Reply With Quote
Old   June 15, 2013, 05:09
shiv
shash is on a distinguished road
hi pedro,
What about expanding the log and using codedFixedValue (http://www.cfd-online.com/Forums/ope...condition.html) , as i am a newbie my knowhow is limited too. Expect this may help
shash is offline   Reply With Quote
Old   June 15, 2013, 11:25
Retired Super Moderator
Bruno Santos
Greetings to all!
@Pedro: OpenFOAM 2.0 or 2.2.0?
If it's OpenFOAM 2.2.0, read the instructions on this post: http://www.cfd-online.com/Forums/ope...tml#post415028 post #16
Best regards,
Bruno
Old   June 17, 2013, 05:08
Pedro Ramos
Hello.
Thanks. Yes, It's OF 2.2.0. I'll try install it and input the log profile with swak4foam.
Regards,
Old   June 17, 2013, 05:30
Pedro Ramos
Cheers,
L
Thanks, but I'm using InterFoam with LES model.
Old   June 17, 2013, 10:49
Lieven
Ok, completely different situation.
The logarithmic velocity profile is the profile a time averaged profile. This profile does not exist as instantaneous profile so it is physically not correct to impose the log-profile directly at the inlet.
the most correct thing to do is use an 'infinite inlet' to generate profiles which result in the log-profile when they are time averaged. Two ways to do this:
1. Do a separate simulation of a cyclic channel and store every inlet
2. Increase the length of the inlet and use the mapped BC at the inlet.
Cheers,
Lieven
Old   June 19, 2013, 06:06
Unhappy
Pedro Ramos
Cheers,
Lieven
Hi Lieven, thanks for your help.
Which boundary condition should I put in the bed to to the second suggestion that you gave me? I put the no slip condition, like this:
bed - U
type fixedValue;
value uniform (0 0 0);
U.txt
And the contour of the velocity in the midplane of the channel is: http://d.pr/i/ZWvo
The distance between the inlet and the pille is 1 meter. Should I keep the bed boundary condition and increase that distance?
Best regards.
Old   June 19, 2013, 08:22
Lieven
Hi Pedro,
You should use the 'mapped' boundary condition for that. Have for example a look at
If you google a bit or search this forum, I'm sure you will find more information on it if the link about is not enough.
Cheers,
Lieven
boundary condition, inlet, logarithmic, profile, velocity
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
How to apply an outlet velocity profile to another inlet? siw FLUENT 4 April 10, 2013 11:19
How to prescribe fully developed turbulent velocity profile at inlet? nore5 OpenFOAM Running, Solving & CFD 1 February 22, 2013 09:30
Export & Import Velocity profile as Inlet eRzBeNgEl STAR-CCM+ 6 March 26, 2012 05:16
inlet velocity profile in Polyflow srinu FLUENT 0 January 16, 2003 20:25
