About Umean
Like Tree4Likes
  • 1 Post By kkpal
  • 3 Post By cfdonline2mohsen
Old   June 25, 2013, 04:52
Default About Umean
kkpal is on a distinguished road
dear all,
I put fieldaverage function into controlDict, and I run the simulation for, say 100s, then I stop here. Since at the beginning of the simulation non-physical phenomenon might occur, this would make the average filed, like UMean and pMean inaccurate.
To eliminate the effect from non physical phenomenon, I resume the simulation at t=100s. From then on, are UMean and pMean calculated from t=100? or are the values before t=100s still be counted into the average field?
ScarFace likes this.
kkpal is offline   Reply With Quote
Old   June 25, 2013, 13:52
cfdonline2mohsen's Avatar
Mohsen KiaMansouri
cfdonline2mohsen is on a distinguished road
Dear Kai,
Usually the averaging must be done after the full convergence i.e. in your case you must turn on averaging after t=100sec (Not from t=0sec) then continue your run for another 100sec i.e. you should sample your data at t=200sec.
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.”
cfdonline2mohsen is offline   Reply With Quote
Access UMean at runtime deji OpenFOAM Programming & Development 3 April 25, 2016 19:20
Umean and U xiyuqiu OpenFOAM Pre-Processing 9 May 19, 2013 18:55
Whatbs the meaning of variables in the computed results yfjma OpenFOAM Post-Processing 8 November 12, 2012 01:52
Error in channelOodles tutorial alberto OpenFOAM Bugs 62 June 8, 2010 07:13
Umean balakrishnan OpenFOAM Running, Solving & CFD 4 March 11, 2005 11:31
