Conjugated heat transfer problem:chtmultiregionSimpleFoam
Old   August 12, 2013, 00:54
Default Conjugated heat transfer problem:chtmultiregionSimpleFoam
Ank
ankur
Ank is on a distinguished road
Dear all,
I am trying to solve a conjugated heat transfer problem. There are four rows of tubes with external circular fins on it. The tubes are given a constant temperature and then the conduction through the fins has to be considered. The outside fluid is air at a constant temperature and velocity. I am able to run the tutorial given in the openfoam but I am finding it to apply to my case. Another problem is I am making the geometry in Gmsh, can anybody help me how do I setup the case with the mesh from Gmsh. I am attaching a snapshot of my problem. Kindly have a look at it.
Ank is offline   Reply With Quote
Old   August 12, 2013, 04:51
Elvis
elvis will become famous soon enough
what about using Engrid (it is opensource software, free of charge) it creates OF meshes and the example is made for conjugate heat transfer with OPENFOAMŪ's chtMultiRegionSimpleFoam ?
https://github.com/enGits/engrid/wik...heat-exchanger
To create Geometries engrid prefers to get geomīs from blender
and you should also should be able to import your gmesh stuff
elvis is offline   Reply With Quote
Old   August 12, 2013, 05:20
Ank
ankur
Hey
Thanks for the quick reply.
I am not familiar with Engrid but I have downloaded it and will try to understand how it works.
I can create different volumes with gmsh also, for example fin is the solid part in my case and each fin is circular in shape with 6 faces. I have four fins, so is it like I have to make solid 1, solid 2, solid 3, solid 4 and then I have to make solid1_top, solid1_bottom etc..? Please guide me if u have any idea about this. I have single fluid region which is air, so one volume for that would be enough.
Old   August 13, 2013, 03:37
MSarkar
msarkar is on a distinguished road
Originally Posted by Ank View Post
Hey
Hi Ankur,
You can continue using gmsh if you want. It is not very difficult to convert the gmsh mesh to Foam mesh. You define all the surfaces and volumes properly in your geo file and create mesh. You use gmshToFoam utility to convert your mesh to foam format. If you have single mesh file for fluid and solid, you can use topoSet and subsetMesh to create appropriate regions. If conditions are same for all your solid regions, you can define one solid volume including all solids. A sample bash script is attached here. This shows the process for two regions.
File Type: gz Meshconversion.tar.gz (615 Bytes, 27 views)
msarkar is offline   Reply With Quote
Old   August 13, 2013, 04:25
Elvis
Engrid has it own discussion here on CFD-Online
http://www.cfd-online.com/Forums/engrid/
Engrid has itīs pros and cons, there is interesting development to come like "handling polyhedral cells directly inside engrid" or engrid is one of the few mesher supporting SU2
Oliver Gloth the "spiritus rector" of engrid is also here http://www.cfd-online.com/Forums/members/ogloth.html
Old   August 13, 2013, 05:14
Ank
ankur
Hey Msarkar,
Thanks alot for the help. I know how to use Gmsh and to run its mesh in openFoam, the only problem is the conjugate type problem in which how to divide the regions etc..but you have told me useful things and I am going to work upon it and will get back to you.
Old   August 13, 2013, 05:16
Ank
ankur
Hey Elvis,
I am going to see the Engrid also, It will take sometime to understand this new software, if I find it easier than Gmsh then will try to solve my problem by Engrid. As msarkar has replied that it is possible to make the mesh in Gmsh also so I am going to use Gmsh for now. Thanks for the help..I will see if its easy to learn Engrid.
Old   August 13, 2013, 13:42
Ank
ankur
Hey Msarkar,
Do we have to give the bounding box info ourselves? because topoSetDict.fluid1 is supposed to be already present..as I have understood.
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
