interfoam:a problem with Air-phase convective-term treatment |
March 31, 2014, 02:10 |
xuhe-openfoam
Rep Power: 12 |
hello!
i modify the convective-term of the UEqn of interfoam. the "alpha1" is volume fraction! there are two ways that i test. the first way: fvVectorMatrix UEqn ( fvm::ddt(rho, U) + alpha1*fvm::div(rhoPhi, U) + turbulence->divDevRhoReff(rho, U) ); and, type "wmake" in the terminal. then , i success ! the second way: fvVectorMatrix UEqn ( fvm::ddt(rho, U) + (fvm::div(rhoPhi, U))*alpha1 + turbulence->divDevRhoReff(rho, U) ); and type "wmake" in the terminal. then , i failed !!! there are some information come out in the terminal: Code:
/home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvMatrix.C:2293:34: 附注: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::operator*(const Foam::dimensioned<double>&, const Foam::tmp<Foam::fvMatrix<Type> >&) /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvMatrix.C:2293:34: 附注: template argument deduction/substitution failed: In file included from interFoam.C:90:0: UEqn.H:4:31: 附注: cannot convert ‘Foam::fvm::div(const surfaceScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::Vector<double>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]((*(const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>*)(& U)))’ (type ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’) to type ‘const Foam::dimensioned<double>&’ In file included from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/one.H:64:0, from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvmDdt.H:40, from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvm.H:43, from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvCFD.H:10, from interFoam.C:40: /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/oneI.H:36:20: 附注: template<class Type> const Type& Foam::operator*(const Type&, const Foam::one&) /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/oneI.H:36:20: 附注: template argument deduction/substitution failed: In file included from interFoam.C:90:0: UEqn.H:4:31: 附注: cannot convert ‘alpha1’ (type ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’) to type ‘const Foam::one&’ In file included from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/one.H:64:0, from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvmDdt.H:40, from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvm.H:43, from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvCFD.H:10, from interFoam.C:40: /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/oneI.H:42:20: 附注: template<class Type> const Type& Foam::operator*(const Foam::one&, const Type&) /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/oneI.H:42:20: 附注: template argument deduction/substitution failed: In file included from interFoam.C:90:0: UEqn.H:4:31: 附注: cannot convert ‘Foam::fvm::div(const surfaceScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::Vector<double>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]((*(const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>*)(& U)))’ (type ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’) to type ‘const Foam::one&’ In file included from interFoam.C:61:0: /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/readTimeControls.H:38:8: 警告: 未使用的变量‘maxDeltaT’ [-Wunused-variable] make: *** [Make/linux64GccDPOpt/interFoam.o] 错误 1 sxh@sxh-virtual-machine:~/OpenFOAM/sxh-2.2.0/project/fsi/src/xuheinterFoam$ thanks! |
interfoam;ueqn |
problem with two phase flow (air injected in water) | miles_davis | OpenFOAM | 15 | March 31, 2021 09:36 |
Thermal phase change set up problem | Danial Q | Main CFD Forum | 1 | July 10, 2014 14:41 |
Two phase flow problem | jignesh_thaker2007 | OpenFOAM | 2 | August 2, 2012 16:59 |
two phase reaction problem | pan_zh | OpenFOAM Programming & Development | 0 | February 5, 2012 23:50 |
Help - Two Phase Flow - Convergence Problem | R.Sureshkumar | Main CFD Forum | 1 | February 22, 2000 03:24 |
