February 3, 2014, 07:15 |
Buoyant Bouss Pimple Foam Documentation
Luca
Rep Power: 12 |
Hi people,
I'm a engineering student in Italy and I'm working on my thesis that treat the validation of BuoyantBoussPimpleFoam solver. Is there any paper, thesis, document, article .... where it's explained how OF works (also in general if not with this solver) ? In my thesis I have to explain the algorithm, governing equations, turbulence model, etc. Thanks. Luca |
February 3, 2014, 07:52 |
Anton Kidess
Rep Power: 30 |
Hey Luca, did you use the search function?
https://www.google.nl/search?q=openf...hannel=suggest If you need more information, can you please outline why the existing threads are not sufficient?
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
February 3, 2014, 08:52 |
#3 | |
Luca
Rep Power: 12 |
it's not sufficient because I don't need tutorials or example of simulations. I have to explain how OF works before to explain my case .... the algorithm, the discretization, the "structure" ... I could write it by myself but for be quickly I wanted find some references. Thanks. |
February 3, 2014, 18:49 |
Joachim Herb
Rep Power: 21 |
If you google for openfoam and master or PhD thesis you will find a lot of documents which all include some explanation of OpenFOAM, e.g. http://www.foamcfd.org/resources/theses.html
buoyant boussinesq, convection, heat transfer, openfoam, thesis |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
