How feasible/convenient is it to model this furnace in OpenFoam ?
Old   April 3, 2014, 18:05
Default How feasible/convenient is it to model this furnace in OpenFoam ?
Ankur
ankur_kr is on a distinguished road
Hi all,
I have been using Ansys FLUENT to model a steam methane reforming furnace (diagrams attached). But now I plan to use OpenFoam to be able use super-computing facility at my university. I was wondering if someone can give me some idea about the level of customization that would be needed for this model.
Model details:
There is a rectangular furnace (5.5m X 4.5m X 12.5m) with inlets at the top and outlets along side walls at the bottom. Several cylindrical tubes are present inside the furnace with inlets at top and outlets at the bottom. In the furnace methane combustion occurs. A different reaction (methane -- > Hydrogen) takes place inside the tube which uses the heat released by combustion in the furnace. So I would need solvers for combustion (or species transport), turbulence, radiation, reaction modeling etc. The furnace acts as one volume unit while each tube acts as individual volume unit. All these domains are solved simultaneously.
Also, regarding mesh generation, would it be recommended to use fluentMeshToFoam to reuse the mesh I have created using Gambit or should I remesh using snappyHexMesh ?
Thanks,
Ankur
ankur_kr is offline   Reply With Quote
Old   April 4, 2014, 05:45
Olivier
olivierG is on a distinguished road
Take a look at reactingFoam and fireFoam. You would use fireFoam as reactingFoam doesn't have radiation, but the settings are similar (just disable pyrolisys ).
If you already have a good mesh, use the fluentMeshToFoamto convert.
regards,
olivier
olivierG is offline   Reply With Quote
Old   April 4, 2014, 15:36
Ankur
Thanks Olivier. I will explore your suggestions.
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 09:29
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
OpenFOAM: LES turbulence model names Ollie OpenFOAM 5 January 7, 2013 10:24
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 10, 2007 23:23
