Unknown patchField type compressible::alphatWallFunction for patch type wall |
November 12, 2013, 11:45 |
Daniel
Hi at all!
I´m a greenhorn regarding openFoam and I've no idea , how to fix this error below. I use the chtMultiRegionFoam-Solver to simulate the the thermal discharge in wind tunnel. So I think I need the compressible::alphatWallFunction as patch type for wall function, or not?!? Do anyone knows what's wrong about my case?!? PLEASE HELP!! Code:
--> FOAM FATAL IO ERROR: Unknown patchField type compressible::alphatWallFunction for patch type wall Valid patchField types are : 97 ( MarshakRadiation MarshakRadiationFixedTemperature advective alphatJayatillekeWallFunction alphatWallFunction buoyantPressure calculated codedFixedValue codedMixed compressible::epsilonLowReWallFunction compressible::epsilonWallFunction compressible::fWallFunction compressible::kLowReWallFunction compressible::kqRWallFunction compressible::omegaWallFunction compressible::thermalBaffle1D<hConstSolidThermoPhysics> compressible::thermalBaffle1D<hExponentialSolidThermoPhysics> compressible::turbulentHeatFluxTemperature compressible::turbulentMixingLengthDissipationRateInlet compressible::turbulentMixingLengthFrequencyInlet compressible::turbulentTemperatureCoupledBaffleMixed compressible::turbulentTemperatureRadCoupledMixed compressible::v2WallFunction convectiveHeatTransfer cyclic cyclicAMI cyclicSlip directionMixed empty energyJump energyJumpAMI externalWallHeatFluxTemperature fan fanPressure fixedEnergy fixedFluxPressure fixedGradient fixedInternalValue fixedJump fixedJumpAMI fixedMean fixedPressureCompressibleDensity fixedUnburntEnthalpy fixedValue freestream freestreamPressure gradientEnergy gradientUnburntEnthalpy greyDiffusiveRadiation greyDiffusiveRadiationViewFactor inletOutlet inletOutletTotalTemperature mapped mappedField mappedFixedInternalValue mappedFixedPushedInternalValue mixed mixedEnergy mixedUnburntEnthalpy multiphaseFixedFluxPressure mutLowReWallFunction mutURoughWallFunction mutUSpaldingWallFunction mutUWallFunction mutkRoughWallFunction mutkWallFunction nonuniformTransformCyclic oscillatingFixedValue outletInlet outletMappedUniformInlet partialSlip phaseHydrostaticPressure processor processorCyclic rotatingTotalPressure sliced slip symmetryPlane syringePressure timeVaryingMappedFixedValue totalFlowRateAdvectiveDiffusive totalPressure totalTemperature turbulentInlet turbulentIntensityKineticEnergyInlet uniformDensityHydrostaticPressure uniformFixedValue uniformJump uniformJumpAMI uniformTotalPressure variableHeightFlowRate wallHeatTransfer waveSurfacePressure waveTransmissive wedge wideBandDiffusiveRadiation zeroGradient ) file: /home/dw/OpenFOAM/dw-2.2.1/run/1/trafo_simulation/0/luft/alphat.boundaryField.wall from line 40 to line 42. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.1/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 136. FOAM exiting |
April 10, 2014, 01:15 |
Hamed Moeini
Rep Power: 12 |
Hi dante03
you wrote wrong in patch field type. you should select (write) one of this patch field type. by |
second order schemes | marine | OpenFOAM | 67 | April 11, 2022 18:19 |
boundary conditions for simpleFoam calculation | foam_noob | OpenFOAM Running, Solving & CFD | 8 | July 1, 2015 08:07 |
Error during initialization of "rhoSimpleFoam" | kornickel | OpenFOAM Running, Solving & CFD | 8 | September 17, 2013 05:37 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
