Backflow option for pressure outlet boundary condition
Old   April 30, 2014, 02:46
Default Backflow option for pressure outlet boundary condition
Kan
nwpukaka is on a distinguished road
For this outlet boundary condition with backflow, I want to set turbulence kinetic energy and dissipation rate for this backflow, what kind of boundary conditions should I set? and how does the code determine that this is backflow?
Thanks in advance
Kan
nwpukaka is offline   Reply With Quote
Old   April 30, 2014, 23:45
skyinventorbt's Avatar
Dr. B T KANNAN
skyinventorbt is on a distinguished road
Originally Posted by nwpukaka View Post
Thanks in advance
Kan
Try inletOutletVelocity BC
KANNAN B T
skyinventorbt is offline   Reply With Quote
Old   May 1, 2014, 03:58
Kan
KANNAN B T
Thank you very much, KANNAN.
About this inletOutlet BC, it says it switches U and p between fixedValue and zeroGradient depending on direction of U, for the direction of U, does that mean the normal direction of velocity of bounding cell?
Kan
Old   May 1, 2014, 17:16
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
The direction of U is determined by the sign of the flux ("phi" field) across the patch faces:
https://github.com/OpenFOAM/OpenFOAM...FvPatchField.C
template<class Type>
void Foam::inletOutletFvPatchField<Type>::updateCoeffs()
    if (this->updated())
        return;
    const Field<scalar>& phip =
        this->patch().template lookupPatchField<surfaceScalarField, scalar>
            phiName_
    this->valueFraction() = 1.0 - pos(phip);
    mixedFvPatchField<Type>::updateCoeffs();
On the outlet patches
  • positive flux (out of domain) phi>=0: pos(phi)=1 and valueFraction=0 apply zero-gradient condition
  • negative flux (into of domain) phi<0: pos(phi)=0 and valueFraction = 1 apply the user-specified fixed value
This switching is performed using the mixedFvPatchField:
void mixedFvPatchField<Type>::evaluate(const Pstream::commsTypes)
    if (!this->updated())
        this->updateCoeffs();
    Field<Type>::operator=
        valueFraction_*refValue_
        (1.0 - valueFraction_)*
            this->patchInternalField()
          + refGrad_/this->patch().deltaCoeffs()
    fvPatchField<Type>::evaluate();
Hope this helps,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
Old   May 1, 2014, 20:00
Kan
Originally Posted by fumiya View Post
        return;
            phiName_
Hope this helps,
Fumiya
Thank you very much. Fumiya.
It really helps!
Kan
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
