Cp calculation at points on the surface of a sphere |
DongHo
Rep Power: 12 ![]() |
Hi Foamers
I'd like to compute Cp (pressure coefficient) at some of points on the surface of a sphere, actually, 30 deg, 60 deg, 90 deg from a stagnation point. I know that I can use "pressureTools" function utility though.. I guess I used it incorrectly and could not get Cp values at those points. I will appreciate it if you can let me know how to use exactly "pressureTools" function utility to measure exactly the Cp values at points as indicated on the sphere. Thank you. |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[mesh manipulation] Projecting points to surface | mchurchf | OpenFOAM Meshing & Mesh Conversion | 1 | September 13, 2012 12:21 |
[General] Create surface from points in Paraview | Voyage_gui | ParaView | 0 | December 12, 2011 11:10 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
