February 21, 2016, 07:57 |
OpenFoam error
kvknagaraju
Hello friends ,
I am a newbie to Open FOAM . I am trying to import a "gmsh" file into "OpenFOAM" i have sucessfully converted it into Openfoam format using "gmshToFoam" command but when i want to view it in "paraFoam" the foam is exiting and the error is being displayed as shown below.Please help me to solve this problem. Thanks in advance kvk@kvk-DL-H61MXEL:~/OpenFOAM/kvk-v3.0+/run/tutorials/hydraulicJumpStream$ paraFoam Created temporary 'hydraulicJumpStream.OpenFOAM' --> FOAM FATAL IO ERROR: Cannot find patchField entry for patch0 file: /home/kvk/OpenFOAM/kvk-v3.0+/run/tutorials/hydraulicJumpStream/0/U.boundaryField from line 26 to line 52. From function void Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = Foam::Vector<double>; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] in file /home/kvk/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 197. FOAM exiting kvk@kvk-DL-H61MXEL:~/OpenFOAM/kvk-v3.0+/run/tutorials/hydraulicJumpStream$ foammToEnsight untitled.msh foammToEnsight: command not found kvk@kvk-DL-H61MXEL:~/OpenFOAM/kvk-v3.0+/run/tutorials/hydraulicJumpStream$ gmsh untitled.msh -3 -o test.msh Error : Unknown string option 'General.ExecutableFileName' Error : Unknown string option 'General.RecentFile5' Error : Unknown string option 'General.RecentFile6' Error : Unknown string option 'General.RecentFile7' Error : Unknown string option 'General.RecentFile8' Error : Unknown string option 'General.RecentFile9' Error : Unknown number option 'General.FltkColorScheme' Error : Unknown string option 'Solver.OctaveInterpreter' Error : Unknown string option 'Solver.PythonInterpreter' Info : Running 'gmsh untitled.msh -3 -o test.msh' [Gmsh 2.8.3, 1 node, max. 4 threads] Info : Started on Sun Feb 21 18:15:17 2016 Info : Reading 'untitled.msh'... Info : 170 vertices Info : Vertex numbering is dense Info : 2319 elements Info : Done reading 'untitled.msh' Info : Meshing 1D... Info : Done meshing 1D (0 s) Info : Meshing 2D... Info : Done meshing 2D (0.015954 s) Info : Meshing 3D... Info : Done meshing 3D (0 s) Info : 170 vertices 2319 elements Info : Writing 'test.msh'... Info : Done writing 'test.msh' Info : Stopped on Sun Feb 21 18:15:17 2016 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
