[PyFoam] Problems with the new PyFoam release
Old   December 4, 2014, 12:38
Default Problems with the new PyFoam release
Alex
zfaraday will become famous soon enough
I saw some days ago that a new version of PyFoam was released. I used to have version 0.6.2 but I wanted to try one of its new features so I updated my PyFoam directory by typing on the terminal svn up. The update process seemed to work well. After that I typed sudo python setup.py install to install it again with the new features. I don't know if this is the correct procedure or if I missed some step...
The point is that all the utilities that have been updated or added during the process don't work, but the ones that haven't been modified work normally.
This is the message that shows the terminal when I execute one of the new/updated utilities (pyFoamPrepareCase):
Traceback (most recent call last):
  File "/home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/bin/pyFoamPrepareCase.py", line 3, in <module>
    from PyFoam.Applications.PrepareCase import PrepareCase
ImportError: No module named PrepareCase
I would like to know what I should do to make it work properly. I'm not much used to update repositories so a good explanation will be very welcome.
Thanks in advance,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   December 4, 2014, 15:22
Assistant Moderator
Bernhard Gschaider
Thanks in advance,
Alex
If I interpret your output correctly there should be a file /home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/PyFoam/applications/PrepareCase.py
But before I start guessing (I checked: the file is in the SVN): output of pyFoamVersion.py please
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 4, 2014, 15:29
Alex
Output of pyFoamVersion.py:
Machine info: Linux | linux-cfd | 3.7.10-1.32-default | #1 SMP Thu May 8 00:09:34 UTC 2014 (5978d00) | x86_64 | x86_64
Python version: 2.7.3 (default, Apr 14 2012, 08:58:41) [GCC]
Python executable: /usr/bin/python
Python 2.7 is one development platform for PyFoam (along with Python 3)
PYTHONPATH: /home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/lib/python2.7/site-packages:/home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/lib/python2.7/site-packages:/home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/lib/python2.7/site-packages:/home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/lib/python2.7/site-packages:/home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/lib/python2.7/site-packages:
Location of this utility: /home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/bin/pyFoamVersion.py
  File "/home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/bin/pyFoamVersion.py", line 64, in <module>
    "Fork",PyFoam.FoamInformation.foamFork(),
AttributeError: 'module' object has no attribute 'foamFork'
Old   December 4, 2014, 15:43
Assistant Moderator
Bernhard Gschaider
Seems like your libraries at /home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/lib/python2.7/site-packages are still at the old version (/home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/lib/python2.7/site-packages/PyFoam/__init__.py will probably still show version 0.6.2). Are you sure that setup.py installed them there?
Old   December 4, 2014, 15:58
Alex
This is how my "home/cfd/OpenFOAM/cfd-2.3.x/PyFoam/lib/python2.7/site-packages/PyFoam/__init__.py" looks like:
#  ICE Revision: $Id: /local/openfoam/Python/PyFoam/PyFoam/__init__.py 8489 2013-11-03T19:15:58.198885Z bgschaid  $
""" Utility-classes for OpenFOAM
Module for the Execution of OpenFOAM-commands and processing their output
from PyFoam.Infrastructure.Configuration import Configuration
def version():
    """@return: Version number as a tuple"""
    return (0,6,2)
    #    return (0,6,3,"development")
def versionString():
    """@return: Version number of PyFoam"""
    v=version()
    vStr="%d" % v[0]
    for d in v[1:]:
        if type(d)==int:
            vStr+=(".%d" % d)
        else:
            vStr+=("-%s" % str(d))
    return vStr
def foamVersionString():
    from PyFoam.FoamInformation import foamVersionString
    return foamVersionString()
_configuration = Configuration()
def configuration():
    """@return: The Configuration information of PyFoam"""
    return _configuration
# Should work with Python3 and Python2
It seems that you are (obviously) right, it still shows version 0.6.2. Why has this file not been updated during the process? How can I be sure that the libraries have been installed correctly by setup.py?
Old   December 4, 2014, 16:06
Assistant Moderator
Bernhard Gschaider
def version():
    return (0,6,2)
No idea. Retry running setup.py and check the output it. My guess is that it installs into a different directory
Old   December 4, 2014, 16:13
Alex
This is the output of the setup.py:
running install
running build
running build_py
running build_scripts
running install_lib
running install_scripts
changing mode of /usr/bin/pyFoamDumpConfiguration.py to 755
changing mode of /usr/bin/pyFoamCaseReport.py to 755
changing mode of /usr/bin/pyFoamStandardLogAnalyzer.py to 755
changing mode of /usr/bin/pyFoamBuildHelper.py to 755
changing mode of /usr/bin/pyFoamRunner.py to 755
changing mode of /usr/bin/pyFoamRunParameterVariation.py to 755
changing mode of /usr/bin/pyFoamFromTemplate.py to 755
changing mode of /usr/bin/pyFoamRedoPlot.py to 755
changing mode of /usr/bin/pyFoamBlockMeshRewrite.py to 755
changing mode of /usr/bin/pyFoamWriteDictionary.py to 755
changing mode of /usr/bin/pyFoamModifyGGIBoundary.py to 755
changing mode of /usr/bin/pyFoamExecute.py to 755
changing mode of /usr/bin/pyFoamReadDictionary.py to 755
changing mode of /usr/bin/pyFoamSTLUtility.py to 755
changing mode of /usr/bin/pyFoamInitVCSCase.py to 755
changing mode of /usr/bin/pyFoamAddEmptyBoundary.py to 755
changing mode of /usr/bin/pyFoamPrepareCase.py to 755
changing mode of /usr/bin/pyFoamCreateModuleFile.py to 755
changing mode of /usr/bin/pyFoamJoinCSV.py to 755
changing mode of /usr/bin/pyFoamUpgradeDictionariesTo20.py to 755
changing mode of /usr/bin/pyFoamCreateBoundaryPatches.py to 755
changing mode of /usr/bin/pyFoamCaseBuilder.py to 755
changing mode of /usr/bin/pyFoamEchoPickledApplicationData.py to 755
changing mode of /usr/bin/pyFoamPrintData2DStatistics.py to 755
changing mode of /usr/bin/pyFoamUpgradeDictionariesTo17.py to 755
changing mode of /usr/bin/pyFoamIPythonNotebook.py to 755
changing mode of /usr/bin/pyFoamCompressCaseFiles.py to 755
changing mode of /usr/bin/pyFoamBinarySize.py to 755
changing mode of /usr/bin/pyFoamTestConfiguration.py to 755
changing mode of /usr/bin/pyFoamUpdateDictionary.py to 755
changing mode of /usr/bin/pyFoamClearCase.py to 755
changing mode of /usr/bin/pyFoamEchoDictionary.py to 755
changing mode of /usr/bin/pyFoamClearInternalField.py to 755
changing mode of /usr/bin/pyFoamBench.py to 755
changing mode of /usr/bin/pyFoamNetShell.py to 755
changing mode of /usr/bin/pyFoamPVSnapshot.py to 755
changing mode of /usr/bin/pyFoamPVLoadState.py to 755
changing mode of /usr/bin/pyFoamUtilityRunner.py to 755
changing mode of /usr/bin/pyFoamDumpRunDatabaseToCSV.py to 755
changing mode of /usr/bin/pyFoamComparator.py to 755
changing mode of /usr/bin/pyFoamListCases.py to 755
changing mode of /usr/bin/pyFoamChangeBoundaryName.py to 755
changing mode of /usr/bin/pyFoamPlotRunner.py to 755
changing mode of /usr/bin/pyFoamPlotWatcher.py to 755
changing mode of /usr/bin/pyFoamCopyLastToFirst.py to 755
changing mode of /usr/bin/pyFoamClearBoundaryValue.py to 755
changing mode of /usr/bin/pyFoamAddCaseDataToDatabase.py to 755
changing mode of /usr/bin/pyFoamNetList.py to 755
changing mode of /usr/bin/pyFoamPotentialRunner.py to 755
changing mode of /usr/bin/pyFoamSteadyRunner.py to 755
changing mode of /usr/bin/pyFoamAPoMaFoXiiQt.py to 755
changing mode of /usr/bin/pyFoamMeshUtilityRunner.py to 755
changing mode of /usr/bin/pyFoamMetaServer.py to 755
changing mode of /usr/bin/pyFoamSymlinkToFile.py to 755
changing mode of /usr/bin/pyFoamRunAtMultipleTimes.py to 755
changing mode of /usr/bin/pyFoamSamplePlot.py to 755
changing mode of /usr/bin/pyFoamSGECommand.py to 755
changing mode of /usr/bin/pyFoamSurfacePlot.py to 755
changing mode of /usr/bin/pyFoamCloneCase.py to 755
changing mode of /usr/bin/pyFoamClusterTester.py to 755
changing mode of /usr/bin/pyFoamPackCase.py to 755
changing mode of /usr/bin/pyFoamChangeBoundaryType.py to 755
changing mode of /usr/bin/pyFoamVersion.py to 755
changing mode of /usr/bin/pyFoamConvertToCSV.py to 755
changing mode of /usr/bin/pyFoamDisplayBlockMesh.py to 755
changing mode of /usr/bin/pyFoamCompareDictionary.py to 755
changing mode of /usr/bin/pyFoamClearEmptyBoundaries.py to 755
changing mode of /usr/bin/pyFoamTimelinePlot.py to 755
changing mode of /usr/bin/pyFoamDecompose.py to 755
running install_egg_info
Removing /usr/lib/python2.7/site-packages/PyFoam-0.6.4-py2.7.egg-info
Writing /usr/lib/python2.7/site-packages/PyFoam-0.6.4-py2.7.egg-info
Maybe I should uninstall it before install it again?
Old   December 5, 2014, 08:43
Assistant Moderator
Bernhard Gschaider
running install
running build
running build_py
running install_lib
<<snip>>
You try that. For some reason no library files are copied at all. But there IS a PyFoam-directory (with sub-directories) in the folder where the setup-py is, right?
Old   December 5, 2014, 09:15
Alex
Yes, of course, there is. Why are you asking for that directory? It was there even before I updated the application to 0.6.4 version.
Old   December 7, 2014, 04:36
Assistant Moderator
Bernhard Gschaider
Because I was wondering why it is ignored. And the only thing I could think of is that it was missing for some reason
Old   December 7, 2014, 12:35
Alex
So what could be the problem? Why am I unable to run the new PyFoam version? What should I do to make it run properly?
Old   December 9, 2014, 07:43
Assistant Moderator
Bernhard Gschaider
No idea. I tried setup.py on my machine and there is a whole lot of copying going on between "build_py" and "build_scripts". What is your exact command line? ("python setup.py ...")
Old   December 9, 2014, 13:58
Alex
The command line I executed was, as written in the first post, "sudo python setup.py install". This is the command shown in the wiki I think.
Old   December 9, 2014, 18:58
Assistant Moderator
Bernhard Gschaider
Wanted to be sure
I was only looking at the long output. If I reread every post in the threads before answering I would answer even less. ALSO: I've seen it often enough that people post the output to a different command than the one they gave 5 posts earlier. So the only command line I take seriously is the one given with the output. Everything else is guessing
Concerning the actual problem: for some reason setup.py doers not copy the Library-files. Which is strange because you said they are there. Permission problem is unlikely. Apart from that I have no idea
Tecplot 360 2017 Release 2 manohar1487 Main CFD Forum 0 August 28, 2017 02:08
New CastNet Release: GUI Environment for OpenFOAM and CalculiX MartinB OpenFOAM Announcements from Other Sources 0 January 13, 2017 10:27
FOAM-extend next release (release 3.2) - test phase extended to August 31st fguibault OpenFOAM Announcements from Other Sources 1 September 17, 2015 19:52
Belated Announcement of PyFoam 0.6.5 and swak4Foam 0.3.2 gschaider OpenFOAM Announcements from Other Sources 0 July 29, 2015 18:32
Having problems to Install OpenFOAM 13 release of PowerLab2 ed_teller OpenFOAM Installation 0 June 11, 2007 10:50
