December 10, 2010, 11:00 |
missing p.relax() in pisoFOAM
One can find at the end of simpleFOAM the code line
/ / Explicitly relax pressure for momentum corrector p.relax (); but this line is missing in pisoFoam.C. Why? best regards, V. G. |
December 11, 2010, 00:59 |
Nima Samkhaniani
Rep Power: 24 |
piso Foam is a transient solution so relaxation can not be true for a transient solution look CFD book you can find more about difference between piso and simple algorithm
December 13, 2010, 05:04 |
Anton Kidess
Rep Power: 29 |
You can also use relaxation with transient solutions, see eg. PIMPLE or transient SIMPLE. However, the whole point about the PISO algorithm is to eliminate the need for underrelaxation. I do agree with you VG. should have a look into a CFD book on this though.
September 2, 2013, 23:47 |
#4 | ||
Dongyue Li
Rep Power: 17 |
and whats the difference between p.relax() with PEqn.relax()? BTW, in Verssteeg'book page196, it said: Quote:
September 3, 2013, 04:02 |
#5 | |
Anton Kidess
Rep Power: 29 |
It doesn't really matter that much if you relax UEqn. In fact, you can throw out the solution UEqn completely by deactivating the momentum predictor.
As for your question about the two types of relaxation, this has been answered multiple times in the past, e.g. here. Quote:
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
June 1, 2015, 05:50 |
#6 | |
Dongyue Li
Rep Power: 17 |
In SIMPLE, cuz there is an omission of velocity correction of neighbor cells, using this u^' to correct velocity is moderate. But for pressure, using this u^' to correct pressure is exaggerated. Cause we need to do explicit relaxation in pressure field to make pressure correction to be moderate. For velocity, we need to use relaxation to make matrix solver robuster. Then we use Ueqn.relax.
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html |
p.relax(), pisofoam |
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam | mchurchf | OpenFOAM | 7 | August 6, 2023 09:12 |
Buoundary Condition for PisoFoam | vishal | OpenFOAM | 4 | October 21, 2010 09:17 |
the result of pitzDaily using simpleFoam and pisoFoam | Kr_kim | OpenFOAM Running, Solving & CFD | 1 | March 16, 2010 13:38 |
Problem with paraFoam | ata | OpenFOAM | 14 | November 30, 2009 04:23 |
Missing tets along line when meshing with ICEM CFD | Georges P. Côté | CFX | 6 | March 23, 2006 00:34 |
