Quicker convergence with clear separation? (example with Karman vortex sheet) |
June 8, 2016, 09:42 |
Bruno
Rep Power: 10 |
Hi all,
I wasn't sure where to put this, so I put it here as I'm working with OpenFOAM myself. I'm working through some tutorials and making my own adjustments to hopefully gaining a better understanding. I was doing an example of external flow around a cylinder using icoFoam, developing a Karman Vortex sheet. I wanted to understand better how these fluctiations developed, so I took out part of the cylinder in the wake, keeping all the setup the same. I plotted the results in the same ParaView window, resulting in the following .gif (sorry, tried to compress, currently still 8MB..). Bottom one is obviously the normal cylinder, top one has a chunk missing in the top right. The way I see it, the fluctuations are consistent much quicker in the top case. Is it safe/correct to see that the top case converged much quicker? Is this due to the increased adverse pressure gradient triggering separation more quickly, is it due to an error in my setup or am I missing the point completely? Cheers, Bruno *edit* I feel like maybe this should've gone here? http://www.cfd-online.com/Forums/openfoam-solving/ If a mod agrees and could move it, thanks. |
Von Karman Vortex | Rodrigo Madariaga | Main CFD Forum | 0 | December 13, 2002 17:12 |
Karman vortex street in channel | Ingo Meisel | Main CFD Forum | 0 | August 20, 2001 04:26 |
Karman vortex street | Achilleas Tsompanos | Main CFD Forum | 4 | April 25, 2000 07:26 |
Kármán vortex street in cavitating flow behind bodies in the cavitation tunnel | L. Könözsy | Main CFD Forum | 0 | April 17, 2000 13:16 |
Kármán vortex street (article)? | Vortexstr | Main CFD Forum | 0 | February 9, 2000 06:47 |
