Courrant Number jump due to layer addition and removal
Old   June 17, 2016, 11:40
Default Courrant Number jump due to layer addition and removal
Xiaoyue Zhao
zxyf1 is on a distinguished road
Hi Foamers,
I have been working on a shock tube case for months, using layer addition and removal scheme as my dynamic mesh scheme in order to simulate the motion of diaphragmless shock tube's plate between driven and driver section. The solver I use is rhoCentralDyMFoam which was copied from 3.0.x and modified to implemented in foam-extend-3.0.1.
The problem I have is when the solver try to add an additional layer of cell in the mesh, the Courrant Number will jump from 0.3 to 10 which will cause the solver crashes. Is there any way to solve this kind of problem?
I have been tried increasing the resoultion of the mesh, however it will occur another error, which indicates the temperature is extremely high:
    From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
    in file /usr/local/OpenFOAM/foam-extend-3.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 72
    Maximum number of iterations exceeded.  Rescue by HJ
If you have any idea please tell me, really appreciate that.
Best!
zxyf1 is offline   Reply With Quote
courant number, courant number increasing, dynamic mesh, layer addition removal, rhocentraldymfoam
engineFoam with layers - pressure problems when adding layers mturcios777 OpenFOAM Running, Solving & CFD 23 January 4, 2023 21:56
Segmentation fault in layerAdditionRemoval Foam-extend 3.1 jbettencourt OpenFOAM Running, Solving & CFD 3 March 10, 2016 05:53
engineMesh with layered addition removal mturcios777 OpenFOAM Programming & Development 19 May 20, 2014 18:16
layer removal only- OpenFOAM-1.5-dev phsieh2005 OpenFOAM Running, Solving & CFD 0 July 2, 2010 05:57
How to use the engine solvers with layer addition and removal francesco OpenFOAM Running, Solving & CFD 2 March 19, 2009 03:29
