RAS turbulence model in multiphase Euler solver for dilute particle laden flows |
July 4, 2016, 17:29 |
Rep Power: 14 |
Hi All,
For the twoPhaseEulerFoam solver, we have several RAS turbulence models as listed here: https://github.com/OpenFOAM/OpenFOAM...mpressible/RAS I found that all these models are developed from bubbly flows. So maybe they are not applicable for dilute partile flows with particle volume fraction < 1e-3. So in this small volume fraction, we do not need to consider the inter-collisions and therefore the kinetic theory model cannot be used. So does it means that in the current version of twoPhaseEulerFoam, we do not have any RAS turbulence models can be used? Anyone has experience with this? best regards, OF |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
