Write a script to modify the data in files?
Like Tree2Likes
  • 1 Post By clapointe
  • 1 Post By qi.yang@polimi.it
Old   September 15, 2021, 10:42
Default Write a script to modify the data in files?
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
I wrote a script to arrange the files based on the data post-processed by openfoam automatically, as below. However, I cannot use the original data in the 'p' files. Instead, I have to subtract p by a value. Anyone has ideas to make this change? Thanks.
patchname='patch_ground'
newpatchname='top'
variableFoldername=$patchname
variablename='p'
variaWriteName='p'
cp -r postProcessing/toppressuredata/surface .
for d in ./surface/*
do
mkdir -p ./boundaryData/$newpatchname/$d/
#Write the default headline contents into the files
echo 'FoamFile
    version     2.0;
    format      ascii;
    class       scalarAverageField;
    object      values;
0.0' > ./boundaryData/$newpatchname/$d/$variaWriteName
#copy values from /surface folder to /boundaryData folder
cat 	./$d/$variableFoldername/scalarField/$variablename >> ./boundaryData/$newpatchname/$d/$variaWriteName
#mv ./boundaryData/newpatchname/$d ./boundaryData/newpatchname
done
#Transfer the format of the corresponding 'points' file
echo 'FoamFile
    version 2.0;
    format  ascii;
    class   vectorField;
    object  points;
'  > ./boundaryData/$newpatchname/points
cat  ./$d/$variableFoldername/faceCentres >> ./boundaryData/$newpatchname/points
#Transfer the format of the corresponding 'faces' file
echo 'FoamFile
    version 2.0;
    format  ascii;
    class   faceList;
    object  faces;
' > ./boundaryData/$newpatchname/faces
cat  ./$d/$variableFoldername/faces >> ./boundaryData/$newpatchname/faces
mv boundaryData/top/surface/* boundaryData/top
qi.yang@polimi.it is offline   Reply With Quote
Old   September 15, 2021, 11:16
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
If you are using an "incompressible" solver such as pimpleFoam or simpleFoam, the pressure is not the real pressure. This pressure field p is actually p' which is p' = p/rho. As the value of p' is not of interest for the numerical process (it does not matter if p' has negative values as we don't have any EOS) you commonly need to multiply your pressure value by the density and add a reference pressure such as the atmosphere one. You simply can see it by checking the pressure dimensions in the 0/p file.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   September 15, 2021, 11:36
kimy
Hi Tobi,
Thanks for your reply. I am using interfoam and the p is the real p that I need. Due to the fact that I require dynamic pressure, namely p-rho*g*h. Do you have any ideas to make this change based on my script?
Old   September 15, 2021, 14:21
clapointe is on a distinguished road
The solver actually computes (and writes) both! The field you're looking for is p_rgh (where p == p_rgh + rho*gh) -- you can check e.g. the pEqn to see this to be true.
Caelan
Tobi likes this.
Public git repository : https://github.com/clapointe2011/public
clapointe is offline   Reply With Quote
Old   September 15, 2021, 14:28
kimy
Originally Posted by clapointe View Post
The solver actually computes (and writes) both! The field you're looking for is p_rgh (where p == p_rgh * rho*gh) -- you can check e.g. the pEqn to see this to be true.
Caelan
Yes, I understood this but what makes me confused is that the p_rgh and p is the same at the bottom of the wave. After I used p_rgh or p at the bottom minus rho*g*h is the correct dynamic wave pressure that I need. I don't know why. Additionally, my objective is to process the files. thanks anyway.
Old   September 21, 2021, 05:53
kimy
I found p_rgh is definitely what I need after I modified the coordinates of gemetry. Now it is clear. Thank you both.
Tobi likes this.
Old   September 21, 2021, 11:43
Tobi's Avatar
Tobias Holzmann
Probably you can also change the "hRef" file (not given and is constructed by default).
It is similar to the gravity field and you specify the reference height here. This could solve your problem too.
Take a try and feel free to give feedback.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  9
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       uniformDimensionedScalarField;
    location    "constant";
    object      hRef;
dimensions      [0 1 0 0 0 0 0];
value           0.244;
Keep foaming,
Tobias Holzmann
Old   September 22, 2021, 03:16
kimy
     \\/     M anipulation  |
FoamFile
    format      ascii;
    object      hRef;
value           0.244;
Thank you Tobi. The hRef represents the height where I want to see the dynamic wave pressure or something else. I just put this file into the system folder with any file name?
Old   September 23, 2021, 03:10
Tobi's Avatar
Tobias Holzmann
Hey,
it corresponds to the reference height which is related to:
p_rgh = p - rho*gh
The term gh is created in the createFields.H file:
#include "readGravitationalAcceleration.H"
#include "readhRef.H"
#include "gh.H"
  • read the graviational acceleration file constant/g
  • read the hRef file constant/hRef (if exists - otherwise create one)
  • build the gh file
    Info<< "\nReading hRef" << endl;
    uniformDimensionedScalarField hRef
        IOobject
            "hRef",
            runTime.constant(),
            mesh,
            IOobject::READ_IF_PRESENT,
            IOobject::NO_WRITE
        dimensionedScalar(dimLength, Zero)
As it is stated, the hRef file is read if present in the constant/ folder (named hRef and does have the value (0 0 0) as default. Finally, the gh field is calculated:
    Info<< "Calculating field g.h\n" << endl;
    dimensionedScalar ghRef
        mag(g.value()) > SMALL
      ? g & (cmptMag(g.value())/mag(g.value()))*hRef
      : dimensionedScalar("ghRef", g.dimensions()*dimLength, 0)
    volScalarField gh("gh", (g & mesh.C()) - ghRef);
    surfaceScalarField ghf("ghf", (g & mesh.Cf()) - ghRef);
Hope this helps you.
Tobi
PS: Code snippet taken from v2106
Keep foaming,
Tobias Holzmann
[General] “Upload” vtk data from client to server in paraview script Jack001 ParaView 0 March 8, 2018 07:27
CGNS files contain no data ansys_matt FLUENT 1 August 19, 2016 22:22
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 09:23
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
