Semi-submersible platform free decay test setup stiffness etc. |
June 4, 2018, 05:06 |
Min YANG
Hello everyone.I am studying ocean engineering ,and now I have already known the platform's free decay period in sway,surge and yaw in the model test.
Now I want to use OpenFOAM for free decay test, I had set up four springs as binding forces, and I want to know if there is any way to get the value of anchor, stiffness, and restLength, and then let the platform do the free decay motion, and finally get the same natural period as the model test. . |
anchor, free decay test, stiffness,restlength |
How to plot pitch motion for free decay test? | mo_na | OpenFOAM Post-Processing | 16 | February 25, 2024 15:29 |
META Publishing: free and open-access platform for Electromagnetics and Photonics | metapublishing | Electromagnetics | 0 | December 29, 2016 12:42 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
setup vof test problem | Fang Jin | FLUENT | 1 | June 14, 2005 08:27 |
