March 28, 2018, 05:15 |
Entrance Length in Laminar Pipe Flow
djr4cfd
Rep Power: 8 |
Dear Foamers,
I just started learning OpenFOAM and I thought of simulating the basic problem of fluid flow through a pipe. I made a 2D mesh with a width of 1m and a length of 10m and simulated the flow using simpleFoam. I understand that the entrance length (development length) can be found by measuring the distance from the pipe inlet to the point where the velocity in the axial direction becomes constant. But in my case, the velocity keeps on increasing throughout the length of the pipe. Why is that happening? Is there any other way to find the development length?? Thank you in advance. |
March 28, 2018, 06:17 |
Uwe Pilz
Rep Power: 15 |
I think you mixed something.
The inlet length is the one it need to homogenize the velocity distribution. The mean velocity cannot increase in such a pipe. Please check your b.c.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 28, 2018, 07:53 |
djr4cfd
Rep Power: 8 |
Thank you very much for responding. The boundary conditions are as follows:
Velocity: pipeWall { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform (4.53 0 0); } outlet { type zeroGradient; } Pressure: pipeWall { type zeroGradient; } inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } Is this right?? |
March 28, 2018, 08:11 |
Uwe Pilz
Rep Power: 15 |
This looks good.
March 28, 2018, 08:25 |
#5 | |
Hosein
Rep Power: 14 |
Your boundary conditions are fine for the moment. But based on your information you will need ~57.53 meters to reach to fully developed condition. You may take a look at here "https://www.engineeringtoolbox.com/entrance-length-flow-d_615.html" to calculate your development length. |
March 28, 2018, 09:07 |
djr4cfd
Rep Power: 8 |
Thank you piu58 and einstein_zee. As einstein_zee pointed out, my velocity was very high. I corrected it and now it works well. I appreciate you for finding time to respond to my silly question. Thank you very much.
Multiphase flow in a pipe with a CHT | wissal | CFX | 4 | June 12, 2017 12:15 |
Problems Verifying Laminar Flow in Pipe | dreamchaser | CFX | 3 | September 17, 2014 18:32 |
Laminar pipe flow using 2D axis symmetric geometry | nandiganavishal | OpenFOAM Running, Solving & CFD | 4 | April 1, 2013 00:48 |
Laminar Pipe Flow Simulation/Help Please | Colin | FLUENT | 3 | May 6, 2003 23:07 |
fully developed laminar pipe flow | wendy | CFX | 11 | January 16, 2002 17:12 |
