Floating point exception (core dumped) in icoFsiFoam
Old   September 16, 2016, 08:09
Default Floating point exception (core dumped) in icoFsiFoam
Viraj Belekar
viraj20feb is on a distinguished road
Hello everyone,
I am trying to run a simulation for flow in a 3Dpipe using icoFsiFoam solver. The simulation runs for a few time step and then I get the following error: Floating point exception (core dumped)
Here are the last few lines from the log file
CG:  Solving for Uz, Initial residual = 0.0602607, Final residual = 8.44523e-07, No Iterations 39
CG:  Solving for Ux, Initial residual = 0.0534526, Final residual = 8.99213e-07, No Iterations 43
CG:  Solving for Uy, Initial residual = 0.0592687, Final residual = 8.51608e-07, No Iterations 37
CG:  Solving for Uz, Initial residual = 0.06021, Final residual = 8.46143e-07, No Iterations 39
CG:  Solving for motionUx, Initial residual = 0.998838, Final residual = 8.95747e-07, No Iterations 54
CG:  Solving for motionUy, Initial residual = 0.999454, Final residual = 8.32624e-07, No Iterations 49
CG:  Solving for motionUz, Initial residual = 0.999492, Final residual = 8.03547e-07, No Iterations 49
volume continuity errors : volume = 5.38224e+22, max error = 1.48662e+08, sum local = -3.42232e-10, global = 3.18263e-11
Motion magnitude: mean = 163763 max = 7.13186e+08
BiCGStab:  Solving for Ux, Initial residual = 0.976841, Final residual = 1.62403e-13, No Iterations 1
BiCGStab:  Solving for Uy, Initial residual = 0.973204, Final residual = 2.82037e-13, No Iterations 1
BiCGStab:  Solving for Uz, Initial residual = 0.999744, Final residual = 1.96498e-13, No Iterations 1
CG:  Solving for p, Initial residual = 0.983696, Final residual = 0.704135, No Iterations 1000
CG:  Solving for p, Initial residual = 0.997927, Final residual = 0.136384, No Iterations 1000
Moving mesh time step continuity errors : sum local = -505.028, global = 2, cumulative = 2.00278
I am attaching the complete log file. Can anyone help?
viraj20feb is offline   Reply With Quote
Old   September 16, 2016, 15:20
Taher Chegini
Taataa is on a distinguished road
Considering large courant numbers, there are probably some issues with your boundary conditions, schemes, solution and even time step. So basically there are many possibilities depending on your case setup which you didn't provide.
Taataa is offline   Reply With Quote
Old   September 17, 2016, 02:05
Viraj Belekar
Hi Taataa,
Please find the case files on this link:
HTML Code:
https://drive.google.com/open?id=0B20W2X0QYDYJdGhxQk42dDBpWms
Floating point exception (core dumped), running a new solver Mahyar Javidi OpenFOAM Running, Solving & CFD 6 April 7, 2018 12:43
simpleFoam: floating point exception student666 OpenFOAM Running, Solving & CFD 9 March 13, 2016 18:23
sonicFoam - Floating point eception (core dumped) MSans OpenFOAM Running, Solving & CFD 12 August 4, 2015 05:10
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 19:28
Floating point exception using icoFsiFoam even with zero flow Nikolac OpenFOAM Running, Solving & CFD 0 May 31, 2014 15:32
