September 1, 2011, 20:52 |
rhoCentralFoam Solver
venkat
Rep Power: 15 |
Dear Foamers,
I am unable to understand the code given in the RhoCentralFoam.C i mean the working procedure, but in the user guide given about pisoFoam and IcoFoam. Where should I find the information about the code like " reconstruct(rho)" thanks in advance. |
September 6, 2011, 22:06 |
Alberto Passalacqua
Rep Power: 36 |
There is a paper on the solver:
Christopher J. Greenshields, Henry G. Weller, Luca Gasparini and Jason M. Reese, Implementation of semi-discrete, non-staggered central schemes in a colocated, polyhedral, finite volume framework, for high-speed viscous flows, INTERNATIONAL JOURNAL FOR NUMERICAL METHODS IN FLUIDS, Int. J. Numer. Meth. Fluids 2010; 63:1–21 For the definition of reconstruct: ~/OpenFOAM/OpenFOAM-2.0.x/src/finiteVolume/finiteVolume/fvc/ I hope this helps.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
September 7, 2011, 02:16 |
venkat
Rep Power: 15 |
Dear Alberto Passalacqua thank you very much for your kind information
Regards, |
April 8, 2012, 06:06 |
wangwei
Rep Power: 14 |
Hi alberto,
I want to know that rhoCentralFoam is a steady solver or a transient solver?Thank you |
April 8, 2012, 16:49 |
Alberto Passalacqua
Rep Power: 36 |
It is a transient solver. You can check that easily by looking at the tutorials.
April 9, 2012, 14:54 |
hi
nsreddy
Rep Power: 15 |
There are two types of solvers in openFoam for compressible flows. For example RhoSimpleFoam and RhoCentralFoam. The solution methods (algorithm) are different for the above two solvers. How to choose the solver. And what are all the parameters we have to consider while selecting the solvers.
Regards, |
April 9, 2012, 17:10 |
#7 | |
Alberto Passalacqua
Rep Power: 36 |
The rhoCentralFoam solver uses a density-based approach with central schemes, and it solves the unsteady equations. The choice of the solver depends on the type of flow you have: - Steady/unsteady? - High Mach number (density based approach) / low Mach number (pressure-based approach)? Best,
April 10, 2012, 00:10 |
hi
nsreddy
Rep Power: 15 |
hi alberto,
Thanks for reply, How to find the which solver is the best for different range of Mach Numbers, and is there any limitation for any solver for prescribed Mach Mumber, How to find that. How the results are varies if i use pressure based solvers and density based solvers if i use same problem. what are all the factors we have to consider. Regards, |
April 10, 2012, 20:02 |
#9 | |
Alberto Passalacqua
Rep Power: 36 |
If you have a specific problem in mind, you should provide details about it, so that the question is specific.
April 19, 2012, 08:19 |
#10 | |
Alexander
Rep Power: 17 |
I am using rhoCentralFoam for my transsonic laminar problem. May be I am wrong, but the one of the main feature of rhoCentralFoam I think is using of fully conservative scheme, so the main conservative laws (for example, for energy) are always preserved. I tried sonicFoam and rhoSimpleFoam and found that there were problems with temperature distributions (such problems were discussed on the forum). As for rhoPimpleFoam I cannot get it worked for my case =( So I recommend use of rhoCentralFoam for the problems with Mach number > ~1 |
August 26, 2013, 11:29 |
#11 |
Ehsan
Rep Power: 26 |
Hi
what does the lines for momentum solving in this solver mean? Code:
// --- Solve momentum solve(fvm::ddt(rhoU) + fvc::div(phiUp)); U.dimensionedInternalField() = rhoU.dimensionedInternalField() /rho.dimensionedInternalField(); U.correctBoundaryConditions(); rhoU.boundaryField() = rho.boundaryField()*U.boundaryField(); volScalarField rhoBydt(rho/runTime.deltaT()); if (!inviscid) { solve ( fvm::ddt(rho, U) - fvc::ddt(rho, U) - fvm::laplacian(muEff, U) - fvc::div(tauMC) ); rhoU = rho*U; } Code:
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
November 4, 2016, 11:41 |
#12 |
November 4, 2016, 11:46 |
#13 | |
Hi, I recommend you take a look at the paper by Christopher J Greenshields, Henry G Weller You can find the paper in the following: http://acemap.sjtu.edu.cn/paper/pape...perID=7FEEC30A |
A New Solver for Supersonic Combustion | nakul | OpenFOAM Announcements from Other Sources | 19 | February 27, 2024 09:44 |
[Other] A New Solver for Supersonic Combustion | nakul | OpenFOAM Community Contributions | 20 | February 22, 2019 09:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Development of a Low mach PISO solver | nishant_hull | OpenFOAM Programming & Development | 0 | August 25, 2009 12:48 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
