DS
Rep Power: 10 ![]() |
Good morning, I'm Denis Sangaletti and I would ask a question about the function blockMesh in OpenFoam 3.0.1. I would generate the file cells in polymesh but this is not generated with the function as described in http://cfd.direct/openfoam/user-guide/v3-blockmesh/, but just neighbour, faces, boundary, owner and points files are generated.
I would ask help to generate it if is possible. Thank you very much Best Regards DS |
blockmesh, cells, openfoam 3.0.1 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
