Point is not inside mesh
Old   January 14, 2022, 08:46
Exclamation Point is not inside mesh
Kishan Shukla
engg_student is on a distinguished road
On running snappyHexMesh, it shows the following error:
--> FOAM FATAL ERROR:
Point (0.0104634 0.00873237 0.704833) is not inside the mesh.
Bounding box of the mesh-0.0375 -0.0375 -0.001) (0.0375 0.0375 1.001)
I have followed the right-handed convention while making background mesh using blockMesh. I have attached my blockMesh and snappyHexMesh files.
I have tried different points but the error remains the same. Would really appreciate the help.
Thank You in advance
File Type: zip blockMeshDict.zip (724 Bytes, 2 views)
engg_student is offline   Reply With Quote
Old   January 14, 2022, 11:32
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Too less information.
We cannot debug anything here. Can you provide the log file of snappyHexMesh or even better the case itself? This error is not a result of the locationInMesh point specified inside the snappyHexMeshDict. However, the blockMesh seems to be fine but there is something wired as the bounding box of your blockMesh is:
Checking geometry...
    Overall domain bounding box (-0.15 -0.15 -0.1) (0.15 0.15 1.1)
As we don't know when this error occurs, no support possible.
Please provide more information.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
blockmesh dict, meshing 3d, snappyhexmeshdict
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 13:28
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
