February 17, 2017, 09:17 |
how merge dieselFoam & conjugateHeatFoam
behnam
I want to merge dieselFoam & conjugateHeatFoam solvers in openFoam (1.6) to solve a spary combustion problem in a cylindrical combustion chamber with heat transfer in cylinder walls.
Can anyone help me? How can i do this? I saw MRFconjugateHeatFoam but did not help me. |
February 21, 2017, 03:06 |
Nima Samkhaniani
Rep Power: 24 |
i recommend you to read the programmer guide to get familiar with OpenFOAM programming and try to read and understand some simple codes such as laplacianFoam, then try to combine these two solvers.
There is a book in Persian which can ease the process of OpenFOAM learning and programming for you (look here). If you need some one to help you to write the code. send me a message.
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
conjugateheatfoam, dieselfoam, openfoam 1.6-ext |
[ICEM] ICE Mesh in ICEM - Block merge | AA29 | ANSYS Meshing & Geometry | 19 | March 23, 2018 06:08 |
merge two connectors | v_herw | Pointwise & Gridgen | 1 | August 28, 2014 09:14 |
[ICEM] Two boxes connected by a cylinder, blocks merge where I don't want them to merge. | Polarbear | ANSYS Meshing & Geometry | 4 | April 30, 2014 15:21 |
[ICEM] Merge mesh - non manifold vertices | BrolY | ANSYS Meshing & Geometry | 4 | October 30, 2010 22:07 |
about merge mesh | lian | Main CFD Forum | 3 | February 29, 2008 10:47 |
