Mesh quality issue
Old   March 1, 2017, 22:24
Default Mesh quality issue
JIN WEIGUO
Mark JIN is on a distinguished road
Hi Friends,
I'm having an issue of mesh quality. If you look at the two figures I attached, the meshes at the transition areas between buildings and open spaces are quite coarse. Actually when I view the velocity result, the meshes look even worse and not fluent at all.
Can anyone help tell the reason and advice? I used snappyHex mesh to generate meshes.
Thanks in advance.
Mark
Mark JIN is offline   Reply With Quote
Old   March 6, 2017, 23:08
JIN WEIGUO
Can anyone give any advice?
Old   March 7, 2017, 00:08
Antimony is on a distinguished road
You have a pretty big change in your mesh size over a small area. Try to make the change in size more gradual.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   March 7, 2017, 03:12
JIN WEIGUO
Originally Posted by Antimony View Post
Cheers,
Antimony
Hi Antimony,
Thanks for your reply.
I tried to increase 'ncellsbetweenlayers' from 5 to 15. Mesh quality looks better now. But still I can see two different colors (U magnitude) at the transient potion of two adjacent layers. Seems like somewhere wrong with my ground boundary condition.
Regards,
Mark
Old   March 7, 2017, 03:38
JIN WEIGUO
Cheers,
Antimony
Hi Antimony,
Actually, that 'color contrast' phenomenon at transient portion only happens on the surface within one cell distance from coordinate Z=0.
[mesh manipulation] Does extrudeMesh affect mesh quality in non extruded cells? Blanco OpenFOAM Meshing & Mesh Conversion 3 February 25, 2023 08:19
[ICEM] Unexplained changes of mesh quality and blocking approach salumi ANSYS Meshing & Geometry 9 November 23, 2016 04:14
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
early stall, poor convergence, and mesh quality everest CFX 2 May 12, 2010 16:27
mesh quality and independency..!?? michelle CFX 0 October 15, 2007 05:50
