IcoFoam unstability, courant number gets large! |
June 16, 2010, 13:11 |
vivien
Rep Power: 17 |
Hi, everyone,
I am trying to run a icoFoam with a big mesh. the mesh contains very small elements. I have run the checkMesh and it shows to be ok. I start the simulation with very small time steps(10-7) and it gives a courant number about 0.02. But after a certain interations, the courant number start to increase and the simulation becomes unstable, can somebody give me suggestions? Many Thanks! Vivien FVscheme ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) Gauss linear; } divSchemes { default none; div(phi,U) Gauss upwind; } laplacianSchemes { default none; laplacian(nu,U) Gauss linear limited 0.7; laplacian((1|A(U)),p) Gauss linear limited 1.0; } interpolationSchemes { default linear; interpolate(HbyA) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; } FVsolution solvers { p ICCG 1e-06 0; U BICCG 1e-05 0; } PISO { momentumPredictor yes; nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } CheckMesh Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 1412976 faces: 15410430 internal faces: 14837762 cells: 7562048 boundary patches: 4 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 7562048 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology walls 103946 52781 ok (non-closed singly connected) inlet 349 198 ok (non-closed singly connected) outlet 460 256 ok (non-closed singly connected) walls 467913 234323 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.066982359 -0.047683548 1.6543907) (-0.019686867 0.037543221 1.6653831) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (1.1197576e-17 -1.7322355e-17 1.4746822e-16) OK. Max cell openness = 2.7923378e-16 OK. Max aspect ratio = 5.5543271 OK. Minumum face area = 6.476086e-12. Maximum face area = 9.1024527e-08. Face area magnitudes OK. Min volume = 1.1082091e-17. Max volume = 6.4997273e-12. Total volume = 1.9463392e-06. Cell volumes OK. Mesh non-orthogonality Max: 66.920089 average: 14.782049 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.71939697 OK. Mesh OK. |
June 18, 2010, 10:26 |
toto
Rep Power: 16 |
you need relaxation factor. Let me know, if it doesn´t woork
June 18, 2010, 10:31 |
vivien
Rep Power: 17 |
I thought I can not put a relaxation factor in transient simulation? Correct me if I am wrong...
Thanks! Vivien |
June 18, 2010, 10:53 |
#4 | |
Alberto Passalacqua
Rep Power: 36 |
Since you use a fully tetrahedral mesh, you might want to use limited schemes for the gradients, and perform some non-orthogonal corrector step (your mesh is borderline, with max non-orthogonality ~ 66). P.S. What version of OpenFOAM are you using? Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
June 18, 2010, 11:07 |
toto
Rep Power: 16 |
I am using OpenFOAM 1.5
June 18, 2010, 11:51 |
Christian
Rep Power: 16 |
I got approximately the same problem and you can fix it as Alberto propose by using pimpleFoam or transientSimpleFoam with relaxation. However the problem will remain if the time step that you use is too big. Indeed your flow will not be converged at each time step... I am still trying to find something in order to run large time step in unsteady simulation. Best regards Christian |
June 18, 2010, 12:38 |
larger time steps
Christian Lucas
Rep Power: 17 |
Hi Christian,
one way to run a transient simulation with larger time steps can be achieved by including an additional loop in the solver, e.g. interFoam. In interFoam, this loop has to be constructed in a way, that it includes the pressure and the velocity equation. Additionally, you must include relaxation within the loop by using the "storePrevIter" function before the calculation of the “p” and “u” equation and the "relax" function has to be used afterwards. However, I am not sure if including this additional loop will result in other problems with the solver. Regards, Christian |
June 18, 2010, 14:46 |
Christian
Rep Power: 16 |
Hi Chris Lucas,
Thank for the post, I will take a look at the code of interFoam. But in fact, I should give you more informations about my case. I have modified the pimple solver: - Time loop: increase time step and apply dynamic mesh motion. - Pimple loop: Solve the U equations, apply under-relaxation and correct turbulence. - Piso loop: Store previous pressure, solve pressure equation and apply under-relaxation. I should also mention that I can reached convergence with bigger time step by increasing the number of pimple loops. However, in this case I have no significant improvement in computational time compare to the small time steps. As my mesh is between 10 and 25 millions of cells, I have to take care about the time of my simulations. Best regards, Christian |
October 7, 2010, 03:25 |
PimpleFoam for TubDyM solver in OF 1.5-dev
#9 |
Aldo Iannetti
Rep Power: 16 |
Is there someone who wants tu debug and correct my pimpleFoam solver applied on turbulence and dynamic meshes solver? Thanks |
October 15, 2010, 15:09 |
#10 |
hi all of foamers
i have one question, why when i use icoFoam for cylinder case stady (standard case in OF) for centimeter dimention & velosity mgnitude 1m/s at the left pach,this error " floating point exception (core dumped) " occurs and the simulation becames unstable ? |
July 23, 2013, 12:48 |
#11 | |
Rep Power: 13 |
Hi All,
Now I have the same problems. If the parameter nOuterCorrectors is set to be 1 in transient time marching, then is it still meaningful to use the velocity and pressure under-relaxation factors? Because in this case, there are not outer iteration steps. Quote:
March 9, 2017, 03:45 |
courant number increase
#12 |
Bill Wang
Rep Power: 11 |
Dear all,
I wonder if any one has found a solution about this problem, please let me know. I tested one structure, there is no error and the results are good; but if I change the structure, there comes the problem. Thank you in advance. Best Regards, Bill |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
RMS Courant Number vs MAX Courant Number | zoozoozoo | Main CFD Forum | 3 | June 12, 2012 13:44 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Courant number | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | May 29, 2006 17:20 |
