How to define in inlet boundary condition a time-varying and non-uniform condition
Like Tree1Likes
  • 1 Post By piu58
Old   June 2, 2017, 15:48
Exclamation How to define in inlet boundary condition a time-varying and non-uniform condition
Ahmed Elshaer
ahmyaser is on a distinguished road
I am trying to set an inlet boundary condition for a simulation similar to wind tunnel testing.
The inlet boundary condition for the velocity should be a table or list (that I have already generated using some numerical models)
The table has the velocities as a matrix that has a number of rows equal to the inlet cells or faces, and a number of columns equals to the number of time steps for the LES simulation.
I will be using the pisoFoam model and I wonder what type of boundary condition to map these list that varies with location and time step.
I tried to use nonuniform List<vector>, but it only varies with location and doesn't vary with time
Also, the timevaryingmappedfixedvalue varies with time and doesn't vary with location
Can anyone help me with this please?
ahmyaser is offline   Reply With Quote
Old   June 3, 2017, 01:08
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
There may be more advanced techniques, but there is also an easy way: Stop the simulation after each time step, use a script to change the b.c. and start the next time step.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   June 3, 2017, 22:35
Ahmed Elshaer
Thank you very much piu58, Can you give me a quick guidance on how to to change the b.c each time step ???
Thanks again
Old   June 4, 2017, 00:01
piu58's Avatar
Uwe Pilz
I don't konw in which form your b.c. exists. The easiest way is to prepare pattern files for all the b.c. objects in your 0 directory in the form
internalField   nonuniform List<scalar>
32336
#0
You may replace the #0 and so on by a sed script which you generate from your list:
's/#0/myBoundaryCondition_0/'
's/#1/myBoundaryCondition_1/'
ahmyaser likes this.
Uwe Pilz
Old   June 5, 2017, 11:48
Ahmed Elshaer
32336
#0
Thank you very much, piu58. for your great help and sorry for asking so many questions as I am new somehow to openFoam. I just wonder how can I let the solver know that this list is assigned to that time step? in other words, how do I link each time step to a certain list of inflow?
Your help is so much appreciated !!
Old   June 5, 2017, 12:43
piu58's Avatar
Uwe Pilz
The solver read what it is in the <timestep> directory. At the beginning this is the 0 folder. You have to manipulate / replace the files in the directory of the last timestep.
Of course you have to set the startFrom entry in the controlDict file to latestTime.
Uwe Pilz
Old   June 5, 2017, 12:45
Ahmed Elshaer
That is a great idea!! thanks a lot. you are a lifesaver
Old   June 5, 2017, 12:48
Ahmed Elshaer
just a last (hopefully) question to make this replacement for each time step. where should I do a script for that? is it at the controlDict derctory?
Old   June 5, 2017, 15:10
piu58's Avatar
Uwe Pilz
You need to let the simulation run by a shell script in the form
loop:
- prepare the b.c. with sed
- start pimpleFoam or what solver you want to have (needs to stop after one time step)
endloop
Uwe Pilz
Old   June 5, 2017, 15:18
Ahmed Elshaer
loop:
endloop
Thanks, can you let me know what is (sed) ?
