June 21, 2017, 22:15 |
interFoam stops after a while
Elham
Rep Power: 16 |
I have a 3D channel of air. There are two parallel cyclic walls and two normal walls. The turbulent is generating by mapping the velocity from the middle of the channel to the inlet. The mesh is refined as a sphere in the channel by snappyHexMesh. Then I put a water droplet as big as the sphere in the same location by setFiledDict. When I run interDyMFoam for the first steps the droplet starts moving but at t=0.0005sec it stoppe with the following error: --> FOAM FATAL ERROR: Not implemented From function processorCyclic::coupledFvPatchField<Type>::snGrad () in file lnInclude/coupledFvPatchField.H at line 153. I tried to change the mesh or even the size of the droplet but the problem exists. I also tried interFoam but didn't work either. The reason that I did not directly setFields for locating the droplet is the turbulent flow that makes the droplet explodes. So I map velocity fields from a channel that has a wall sphere instead of a droplet. Thanks for helping me. Elham |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 06:36 |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
interFoam stops without error | tinu80 | OpenFOAM Running, Solving & CFD | 6 | June 20, 2019 01:35 |
interFoam (HELYX-OS) pressure boundary conditions | SFr | OpenFOAM Running, Solving & CFD | 8 | June 23, 2016 16:36 |
k-e & GAMG interFoam Schemitisation Stability Issue | JFM | OpenFOAM Running, Solving & CFD | 3 | December 1, 2015 05:58 |
