iso surface in Openfoam
Like Tree1Likes
  • 1 Post By farensheep
Old   June 23, 2017, 11:20
Default iso surface in Openfoam
Alexis Marchand
farensheep is on a distinguished road
Hi everyone,
For my simulations I like to have the iso surface of temperature or heat release. But when I look at the vtk file, the output is not smooth at all (see the attached picture). I've tried to smooth it using paraview but the result is still not good (and it is numerically expensive).
Is there a way to improve the iso-surface output? I've tried to look at the doc and I've found nothing about it...
Thank you for your help
gentela likes this.
farensheep is offline   Reply With Quote
Old   June 23, 2017, 11:24
Ali
gentela is on a distinguished road
I have the same problem and haven't found a working way around it!
gentela is offline   Reply With Quote
Old   June 24, 2017, 13:54
JNSN's Avatar
Jan
JNSN is on a distinguished road
Try the latest Paraview 5.4 . Import the foam case directly an generate the iso surface in Paraview. When you switch off decomposepolyhedra option and do not triangulate, you get a nice smooth surface.
Sent from my D5803 using CFD Online Forum mobile app
JNSN is offline   Reply With Quote
Old   June 24, 2017, 14:58
Alexis Marchand
Thank you for your reply.
With paraview it is working but I have to save the fields during my simulation and this is something I've tried to avoid (space consuming).
iso surface, vtk files
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 12:05
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
