Problems in immersedboundary method using icoIbFoam in of-extend4.0
Old   July 13, 2017, 09:28
Default Problems in immersedboundary method using icoIbFoam in of-extend4.0
Dong Zhang
what is on a distinguished road
I want to simluate a flow around Naca0012 foil using IB method in of-extend-4.0. The case is 2D and the Z direction length of the mesh is same with the Naca foil in the .stl file. When I run potentialIbFoam, it encounters "Intersection point is not on symmetry plane ".
In the immersedBoundaryFvPatch.C at line 1053, it says
if
mesh_.nGeometricD() < 3
&& mag(ibCellCentres[cellI].z() - ibPoints[cellI].z()) > SMALL
WarningIn
"immersedBoundaryFvPatch::makeIbPointsAndNorma ls() const"
) << "Intersection point is not on symmetry plane " << nl
<< "C = " << ibCellCentres[cellI]
<< " D = " << ibPoints[cellI] << nl
<< "for 2-D geometry. Adjusting" << endl;
But some of the ibCellCentres[cellI].z() = ibPoints[cellI].z() =0.05 in my case. Can you give me some help? Thank you very much!
Create time
Create mesh for time = 0
SIMPLE: no convergence criteria found. Calculations will run for 3 steps.
Create immersed boundary cell mask
Create immersed boundary face mask
Found immersed boundary patch 0 named ibCylinder
External flow
Number of IB cells: 774
Reading field p
Reading field U
Calculating potential flow
--> FOAM Warning :
From function immersedBoundaryFvPatch::makeIbPointsAndNormals() const
in file immersedBoundaryFvPatch/immersedBoundaryFvPatch.C at line 1053
C = (-9.14326e-06 -0.00767303 0.05) D = (0.00163822 -0.00699302 0.0500001)
--> FOAM Warning :
C = (-9.14326e-06 -0.00461139 0.05) D = (0.000689702 -0.00444315 0.05)
--> FOAM Warning :
C = (-9.14326e-06 -0.00154975 0.05) D = (0.000139054 -0.00153711 0.05)
what is offline   Reply With Quote
foam-extend, icoibfoam, immersedboundary
FVM,FDM AND FEM d Main CFD Forum 4 May 30, 2003 03:19
tidal flow simulation using finite volume method Jason Qiu Main CFD Forum 0 October 20, 2002 02:34
unstructured grid sreekanth Main CFD Forum 1 August 6, 2001 15:09
Solution method for transient problems Roberto Ciardulli Siemens 10 November 28, 2000 04:38
Has the pressure correction method problems? X. Ye Main CFD Forum 17 September 1, 1999 16:14
