Passive Scalar Out of Bounds
Like Tree2Likes
  • 1 Post By floquation
Old   August 1, 2017, 09:04
Talking Passive Scalar Out of Bounds
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello to all,
i've just met some problem with scalarTransportFoam, because i find the scalar is larger than 1 in some points and smaller than zero. I think this is up to the schemes used.
I'm working on OF1612+ and this is my fvSchemes file (the original from pitzDaily case).
I run the direct simulation to find the U field then i copy it in the 0 folder where i run scalaTransportFoam.
Why is my scalar out of bounds? Any Solution?
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,T)      Gauss linearUpwind grad(T);
laplacianSchemes
    default         none;
    laplacian(DT,T) Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
Thanks for help
FlyBob91 is offline   Reply With Quote
Old   August 1, 2017, 09:11
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Use a bounded scheme instead.
Replace your "divScheme" (so the scheme for the convective term) by banana.
Then choose one of the schemes that start with "limited". For example (disclaimer: typed from memory, could contain a syntax error):
div(phi,T) limitedVanLeer 0 1;
FlyBob91 likes this.
floquation is offline   Reply With Quote
Old   August 1, 2017, 10:01
FlyBob91's Avatar
Many thanks Kevin. I wrongly took for granted the solver bounded the scalar between 0 and 1.
Maybe can you suggest me a second order scheme (i noticed that the linear scheme flattens too much the solution) that works good in channel flow?
Old   August 1, 2017, 10:35
floquation's Avatar
Kevin van As
Did you mean "linear" or "linearUpwind"? Since you said "linear" in your last post, but your first post showed that you were using "linearUpwind".
Either way, according to the OF user guide, both "linear" and "linearUpwind" are already second order.
Personally, I am using limitedVanLeer, but what works for my case needs not work for your case. I am performing multiphase simulations with interFoam.
Old   August 5, 2017, 05:29
FlyBob91's Avatar
I tried to use some bounded schemes they seem to limit correctly the passive scalar but, unfortunately, the solution is very far to what i have to obtain.
If you compare the image of what i have to obation with my solution without the bounded condition you can see they are qualitatively similar except for the scalar which is unbounded
The fvSchemes i used are those i reported in the first post.
Then i used these schemes
ddtSchemes
    default         Euler;
gradSchemes
divSchemes
    default         none;
    div(phi,T)      Gauss limitedLinear01 1;
laplacianSchemes
    default         none;
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    T               ;
And here the results. It seems Gauss limitedLinear01 flattens to much the scalar field.
I state my case is a mixing problem in a channel with 2 inlets. At the first Inlet i impose T=1 and at the second T=0 and the images show the outlet of the channel. I'm working on ofv1612+
Another question. Reading the OF user guide i noticed that Gauss limitedLinear01 is followed by another 1. What is his meaning?
Any Idea?
Thanks for help
Old   August 7, 2017, 06:26
FlyBob91's Avatar
Hello to all,
i'm here again. I literally tested alle the limited method as suggested but the problem continues to appear.
Here all the files of my case. Maybe the problem is not the scheme.
ddtSchemes
    default         Euler;
gradSchemes
divSchemes
    default         none;
laplacianSchemes
    default         none;
    default         linear;
snGradSchemes
    default         corrected;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    T
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-06;
        relTol          0;
SIMPLE
    nNonOrthogonalCorrectors 0;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0.5;
boundaryField
    inlet1
        type            fixedValue;
        value           uniform 1;
    inlet2
        type            fixedValue;
        value           uniform 0;
    outlet
        type            zeroGradient;
    walls
        type            zeroGradient;
    movable
        type            zeroGradient;
thanks for help
Old   August 10, 2017, 06:17
FlyBob91's Avatar
Little update!
The Gauss linearUpwind grad(T) for the divergence term seems to be the scheme which, qualitatively, gives best results. Is there a manner to make to mantain it applaying a limit? Os is better if i start to work to the other term as the gradient and laplacian?
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Division by zero exception - loop over scalarField Pat84 OpenFOAM Programming & Development 6 February 18, 2017 05:57
Issue symmetryPlane 2.5d extruded airfoil simulation 281419 OpenFOAM Running, Solving & CFD 5 November 28, 2015 13:09
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 06:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
