LimitedCubic scheme does not work
Old   August 11, 2017, 10:37
Default LimitedCubic scheme does not work
haoyuan zhang
haoyuan is on a distinguished road
hi, everyone
I am learning OpenFoam and trying to test some different schemes in the "interpolationSchemes" . When I test the limitedCubic scheme with the forwardStep case, using rhoCentralFoam, it doesn't work.
There are a numr of schemes that I can't use either, so I want to ask if there is any limitation on the scheme or the rhoCentralFoam. I don't change anything else except the interpolationSchemea in the fvSchemes file.
Sent from my iPhone using CFD Online Forum mobile app
haoyuan is offline   Reply With Quote
Order of accuracy in a combined scheme kaush Main CFD Forum 5 July 21, 2017 05:47
AUSM scheme ? Central Scheme boling Main CFD Forum 7 January 7, 2016 02:41
forward diff scheme vs backward diff scheme zdunol Main CFD Forum 5 November 30, 2015 13:42
RP_Set_Integer does not work in parallel 86lolo Fluent UDF and Scheme Programming 2 July 3, 2014 11:37
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 13:22
