How do you do FSI / co-simualtion?
Old   May 13, 2017, 09:44
Default How do you do FSI / co-simualtion?
Elvis
elvis will become famous soon enough
can you share how do you do FSI / co-simulation?
I have just found
http://carat.st.bv.tum.de/caratusers....php/Users:FSI
http://carat.st.bv.tum.de/caratusers...I/CouplingCode
of course there is mpcci :-)
elvis is offline   Reply With Quote
Old   July 16, 2017, 02:48
Elvis
http://empire.st.bv.tum.de/
Enhanced Multi Physics Interface Research Engine!
EMPIRE is a research tool for co-simulation in the context of field and signal coupling.
http://www.precice.org/
preCICE (Precise Code Interaction Coupling Environment)
Old   July 16, 2017, 04:13
Elvis
https://github.com/davidsblom
Old   December 7, 2017, 16:29
MakisH is on a distinguished road
The FOAM-FSI project you mentioned uses foam-extend 3.2 for both solid and fluid and preCICE for the coupling.
Recently, preCICE got an official OpenFOAM adapter, which currently supports conjugate heat transfer, but is easily extensible to other problems and it should be able to support any solver.
Mechanical fluid-structure interaction is a planned extension and it would be very useful if you wrote a comment on what you would like to see it supporting in the respective GitHub issue! :-)
MakisH is offline   Reply With Quote
FSI: How to transfer static pressure from fluent to ANSYS momo_sjx FLUENT 0 October 9, 2012 13:37
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 04:14
initial file for fsi modeling? mortazavi CFX 0 July 21, 2009 02:06
fsi sun Siemens 8 January 19, 2009 23:17
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
