Open Foam example wind around buildings
Like Tree1Likes
  • 1 Post By Antimony
Old   June 7, 2017, 02:20
Unhappy Open Foam example wind around buildings
Vaidotas Zimnickas
Vaidotas is on a distinguished road
I am quite new CFD moddelling and especially in OpenFoam. I am trying to run OpenFoam example related with wind flow in urban areas however when I trying to run wind around buildings example I face a problem. I get an error like this:
FOAM FATAL IO ERROR:
Could not open "/home/vaidotas/OpenFOAM/vaidotas-4.1/run/windAroundBuildings/constant/triSurface/buildings.eMesh"
file: /home/vaidotas/OpenFOAM/vaidotas-4.1/run/windAroundBuildings/system/snappyHexMeshDict.castellatedMeshControls.features from line 43 to line 43.
From function void Foam::refinementFeatures::read(const Foam:bjectRegistry&, const Foam::PtrList<Foam::dictionary>&)
in file refinementFeatures/refinementFeatures.C at line 97.
What I am doing wrong?
Best regards,
Vaidotas
Vaidotas is offline   Reply With Quote
Old   June 8, 2017, 06:06
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Vaidotas,
In all the tutorials there is a file called Allrun this file is a script to run automatically the tutorial. If you open the Allrun file with a text editor you can see all the commands necessary to run the tutorial. To understand the commands you must know the scripting language but it's not so difficult. In the case of this tutorial you must run:
1) surfaceFeatureExtract
2) blockMesh
3) snappyHexMesh -overwrite
4) simpleFoam
Best Regards,
Paulo
vatavuk is offline   Reply With Quote
Old   June 8, 2017, 06:39
Vaidotas Zimnickas
Dear Paulo,
Thank You for your answer. I tried that, but it does not work, I do not know way.. Problem disappear when I re install OpenFoam completely
Old   February 3, 2018, 08:59
Default WindAroundBuildings
Luis Fernando Espinoza Castillo
LuisPeruArq is on a distinguished road
Originally Posted by vatavuk View Post
Hi Vaidotas,
2) blockMesh
4) simpleFoam
Best Regards,
Paulo
I have a simliar problem, when i executed "simpleFoam" appears this:
Build : v1712
Arch : "LSB;label=32;scalar=64"
Exec : simpleFoam
Date : Feb 03 2018
Time : 08:57:07
Host : "DESKTOP-4NORPPB"
PID : 572
I/O : uncollated
Case : /mnt/c/Users/Public/Documents/tutorials/incompressible/simpleFoam/windAroundBuildings2
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 2
SIMPLE: convergence criteria
field p tolerance 0.0001
field U tolerance 0.0001
field "(k|omega|epsilon)" tolerance 0.0001
Reading field p
--> FOAM FATAL ERROR:
cannot find file "/mnt/c/Users/Public/Documents/tutorials/incompressible/simpleFoam/windAroundBuildings2/2/p"
From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 502.
FOAM exiting
I tried with the original file and then with a copy of the original (so You donīt think that the mistake is the number 2 after the name)....the problem is the file system (I think so)
Please, i need help (SOS)
LuisPeruArq is offline   Reply With Quote
Old   February 4, 2018, 20:07
Antimony is on a distinguished road
I am not sure how you ended up with a time folder of 2. Did you run snappyHexMesh without the -overwrite option?
Simplest thing you can do is to copy the p, U, k, epsilon/omega, nut files from "0" folder to "2" folder and type simpleFoam again. I would think that should solve your problem.
Cheers,
Antimony
LuisPeruArq likes this.
Antimony is offline   Reply With Quote
Old   February 4, 2018, 21:23
Thank you, your suggestion has sense....I īve forgotten the Phrase "-overwrite"
wind flow buildings
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[snappyHexMesh] Problem with parallel run of snappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 5 April 15, 2016 04:12
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
