Print message for ExecutionTime
Old   March 19, 2018, 08:04
Default Print message for ExecutionTime
mahmoodn is on a distinguished road
Using the CUDA solver, I see the following info at each time step
Time = 10
cudaCG:  Solving for T, Initial residual = 9.9545596e-07, Final residual = 9.9545596e-07, No Iterations 0
ExecutionTime = 5.68 s  ClockTime = 5 s
I greped to see which part of the code prints that time. However, there are so many instances and I can not figure out which one is correct. Does anybody know?
mahmoodn is offline   Reply With Quote
Old   March 19, 2018, 08:59
Robert
RobertHB is on a distinguished road
The ExecutionTime is the time needed by the CPU for the iteration step and ClockTime is the "real" Time.
Further information can be found here: Difference between "ExecutionTime" and "ClockTime"
RobertHB is offline   Reply With Quote
Old   March 19, 2018, 14:55
OK. But I would like to know which source file is used for printing that information. As I said, there are multiple instances in the source folder.
Also, from you explanation I think ClockTime should be bigger than ExecutionTime. But I see the inverse. Can you explain more?
Old   March 20, 2018, 04:00
Robert
From my observation the ClockTime is allways a whole number, while ExecutionTime gives the exact fractions. Also ExecutionTime can be smaller or larger (by a few fractions) than the ClockTime.
The printout is from solver.C:
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
Guide: Getting Started with the CFD Online Discussion Forums pete Site Help, Feedback & Discussions 8 July 29, 2016 06:00
[blockMesh] Another cylinder question bendel_boy OpenFOAM Meshing & Mesh Conversion 5 January 6, 2015 06:09
single directional message transmit in parallel model su_junwei OpenFOAM Programming & Development 1 December 17, 2009 08:00
error message susan Siemens 0 August 17, 2007 01:27
Error Message on es-ice [BUG] Wendy Tjia Siemens 0 February 10, 2005 09:40
