The nutUwallfunction in the LES
Old   March 20, 2018, 22:24
Unhappy The nutUwallfunction in the LES
TangYuanzhe is on a distinguished road
Dear everyone.
It's my first time using nutUwallfunction . when I set the nutUwallfunction. I meet some problem.And I am not sure If I am correct.
I use Smagorinsky model and incompress model.and in the /0/nut file,I set
surface
type nutUWallfunction;
value uniform 0;
And in my 0/U file
I set
type fixedValue;
value uniform ( 0 0 0 );
1. So is it correct?
2. when I use nutUwallfunction ,what's meaning of the 'uniform 0' under the 'nutUwallfunction'?
I wish someone can help me.Now I am very worried.
TangYuanzhe is offline   Reply With Quote
Old   March 21, 2018, 02:06
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
This is the initial value. Don't mind for it. The real value will be calculated by the wall function und the course of calculated time.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 21, 2018, 02:32
Dear Uwe Pilz
So whether the 'U' and 'nut' setting is correct?
Old   March 21, 2018, 04:52
piu58's Avatar
Uwe Pilz
Whether ist is correct or not depends on what you wish to simulate (which properties you need at your walls / patches).
Uwe Pilz
Old   March 22, 2018, 03:25
Robert
RobertHB is on a distinguished road
If your surface is supposed to behave like a solid surface in a domain filled with a fluid and if you want 0 m/s flow velocity at your surface, than those settings are correct.
RobertHB is offline   Reply With Quote
LES Filtering: how are the small and large scales equations solved? atmcfd Main CFD Forum 38 March 14, 2016 15:52
Grid difference between wall modeled LES and wall resolved LES hityangsir Main CFD Forum 9 April 17, 2015 12:59
OpenFOAM LES capability questions siw OpenFOAM Running, Solving & CFD 3 January 6, 2015 09:50
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
